Waterborne varnish.
Waterborne varnish.
Home Forums Materials Waterborne varnish.
  • #277862
    Richard Barrett 3
      @richardbarrett3
      Gent's. For my floats I've been told a waterborne varnish is best. Can you buy just a small amount. Most I've seen are in 5 litres, that would last two lifetimes for me.
      Thanks. Richard.
      #29673
      Richard Barrett 3
        @richardbarrett3
        Varnish for floats
        #277863
          Any of the ones sold as "quick drying" or "acrylic" will be water based, should be able to pick up a Ronseal or Dulux Diamonglaze from the local DIY in 250mls
          #277884
          Richard Barrett 3
            @richardbarrett3
            Ahhh! Didn't know that, thanks brilliant. It's simple terminology I don't understand.
            #277887
            John Haine
              @johnhaine32865
              Make sure that it is labelled as water resistant. These varnishes are based on PVA resins I believe, some are not waterproof. If you are not over-concerned about finish, quite a good approach is to use a waterproof PVA glue, slightly thinned down to a brushing consistency, and apply several coats. In the dim and distant I made a couple of "skim boards" for the kids out of 6mm ply and applied several coats of this to seal them against sea water – it worked fine for several holidays except where the sand scratched through the coating..
            Home Forums Materials Topics
