Needle File Recommendations?
Home Forums General Questions Needle File Recommendations?
  • #471382
    Hollowpoint
      @hollowpoint
      Im looking for a good set of needle files and wondered what you guys might recommend?
      I have lots of good quality large sizes (Osborne, Sandvik, Simmonds, Bahco etc) but all my small needle files are cheap crap.
      I don't want to go over about £50 if that is possible. (I know some sets are hundreds of pounds.) The only ones I have considered so far is a set of Swiss Vallorbe and these look like a good contender?
      #27358
      Hollowpoint
        @hollowpoint
        #471383
        roy entwistle
          @royentwistle24699
          Vallorbe aren't bad
          #471385
          Martin Kyte
            @martinkyte99762
            Depends what you want them for. For clockmaking in brass I use Vallorbe but for steel I generally use fairly coarse cheap needle files and chuck them as soon as they stop cutting well. If you are intending to buy a good set mark them up and make sure you have a cheap set for general use to save wrecking your good set. If your good set is for brass do not use them on steel.
            regards Martin
            #471387
            mechman48
              @mechman48
              I too have various sets of needle / diamond files from one source or another, all do the job I want them to do, some I've had for years ( blue / black wallet ) & still cut nicely. In your case I would suggest you go for the Vallorbe as they are considered the best of files.
              George.
              #471392
              Mike Crossfield
                @mikecrossfield92481
                Hollowpoint
                I can recommend the Tome Feteira Swiss pattern needle files sold by Arceurotrade. IMHO close to Vallorbe quality, but at a more acceptable price. Set of 6 was about £38 pounds last time I looked, though I prefer to buy just the shapes and cuts I need.
                #471393
                Hollowpoint
                  @hollowpoint
                  I will be using them on brass mainly, though I do sometimes need them for steel too.
                  #471397
                  Steviegtr
                    @steviegtr
                    I guess if using on the materials you say then diamond type would not be necessary. I have some but only use on hard tooltips.
                    Steve.
                    #471403
                    Hollowpoint
                      @hollowpoint
                      Yes diamond would be overkill I think. I have to admit I don't particularly like them anyway. I feel like I have more control with ordinary files and a good sharp one is a joy to use.
                      #471410
                      Thor 🇳🇴
                        @thor
                        As Roy, my vote is for Vallorbe. The Vallorbe needle files I have were not cheap but they have lasted a long time. If your budget is around £50, maybe these would be suitable?
                        Thor
                        #471412
                        JohnF
                          @johnf59703
                          Vallorbe are possibly the best around, not cheap but they do last extremely well, I have also used Bacho and they are not bad. Not tried Ketan's at Arc yet but intend to do so next time I need some. Most of my work is in tool steels, SS, gauge plate etc.
                          magpie
                            @magpie
                            A shame you can no longer get Stubbs files. I have a set of their needle files I bought in the early 70s. They have been used at least once a week since and are still in good shape.
                            #471417
                            Hollowpoint
                              @hollowpoint
                              I did find these vallorbe files which seem to be good value for money? The only thing putting me off is that in some descriptions they are said to be "lighter manufacture" and "less durable" than the more premium vallorbe offerings?
                              #471425
                              old mart
                                @oldmart
                                I have had some Kennedy diamond files for years and they are good. This firm is selling sets of needle files, no2 cut by Kennedy, hopefully they are also good. My set of 12 Vallorbe files cost me £50 years ago, probably at least £80 now.
                                Rod Renshaw
                                  @rodrenshaw28584
                                  Hi
                                  Some good advice re Vallorbe and Tome Feteira above.
                                  But just to emphasise what Martin said, the traditional watchmakers' advice is that one should keep a set of files for use on brass and never let them anywhere near steel. Apparently any use on steel will take the sharp edge off the teeth and from then on they will only be useful on steel.
                                  Whereas, if kept for use only on brass then one set of decent quality can last a lifetime. So perhaps a buy a good set and a cheap set, and remember which is which?
                                  Rod
                                  #471437
                                  Dave Wootton
                                    @davewootton
                                    I'm a recent convert to Tome Feteira files and needle files from Arc, very pleased with them.
                                    I have been using them on gauge plate for loco valve gear and they are lasting very well. I've also used Vallorbe in the past which were good but I think more expensive, but I was very disappointed in some Bahco files that didn't keep their edge at all.
                                    I do keep separate files for brass, and they seem to last indefinitely, I've colour coded the handles because I'm easily confused.
                                    geoff walker 1
                                      @geoffwalker1
                                      Hi Hollowpoint,
                                      If you want an inexpensive set of small needle files try the 6 piece blue spot mini file set on ebay.
                                      At £3.89 for the set you have little to lose and a lot to gain.
                                      I bought a set from Boyes in York nearly two years ago, I've used them a lot
                                      They are cheap and cheerful but nevertheless great value for money.
                                      Geoff
                                      #471467
                                      Peter Hall
                                        @peterhall61789
                                        I have some Vallorbe needle files, which I use often. I don't know what a set of eight of them would cost today. I bought them 39 years ago.
                                        Pete
                                        #471480
                                        JohnF
                                          @johnf59703
                                          Posted by Hollowpoint on 13/05/2020 15:06:28:
                                          On Amazon it says the supplier is H S Walsh which a well respected supplier of jewellery & clock makers supplies so one would expect them to be genuine Vallorbe / Grobert files — strangely the H S Walsh web site will not open ? maybe the times we are in.
                                          roy entwistle
                                            @royentwistle24699
                                            H S Walsh website just opened for me they are only doing mail order at present
                                            #471510
                                            Bill Phinn
                                              @billphinn90025
                                              Hollowpoint, it may be that you do actually want a cut 2 needle file set. Most people do, as cut 2 is good for general purposes. Personally, I like to have the commoner profiles in cut 4 and cut 6 on hand as well. My Vallorbe 4s and 6s were all bought as individual files, not in a set. Sets of cut 4 or 6 are rather hard to come by.
                                              I notice Arceurotrade's Swiss Pattern needle files sets are available in cut 4 as well as 2, which is a welcome option to have available.
                                              #471533
                                              Hollowpoint
                                                @hollowpoint
                                                Posted by Bill Phinn on 13/05/2020 20:17:22:
                                                That was my other question, not sure what "cut" I want. I think the ones I have are 2's but it seems like cheap 2's are more course than expensive 2's. 🙄
                                                #471561
                                                Pete.
                                                  @pete-2
                                                  Have a look on amazon, Pferd sets for £75~80, a little more than you wanted, but they are good quality.
                                                  #471661
                                                  Kiwi Bloke
                                                    @kiwibloke62605
                                                    I think it's a good idea to define your problem before spending money on a solution. Sets of files (anything?) may seem attractive, and may appear to save a little money, but will you end up with several things in the set which never get used? With files, I think you need a range of cuts at least as much as a range of shapes, and the sets of needle files that I've seen have been of one cut only. I have bought my needle files individually, as needed, and am particularly glad to have been able to get No 6 cut Vallorbe files here in NZ, where it's often difficult to get things that aren't of indifferent quality. And, as others have suggested, you need to keep separate files for ferrous and non-ferrous application. As usual, buy cheap, pay twice…
                                                    #471672
                                                    Martin Kyte
                                                      @martinkyte99762
                                                      Posted by Hollowpoint on 13/05/2020 13:31:41:
                                                      As I said you will need two sets then. Mark your best set up and reserve for Brass which is 'slippery' and needs really sharp files to cut efficiently. Personally I would buy individual files in the shape I need. If you are clockmaking you will occasionally need to modify standard files to get into corners or create safe edges etc.
                                                      regards Martin
