Hi, thanks for the replies, the shape of the slots needs to be as an endmill would make them, an extended circle. ie. two parallel sides and a radius at each end. So I can't use a single spindle unfortunately.
I will order some collet holders tomorrow and try them, if they are not press fit then I will use bearing with grub screw (RA?).
Thanks for your help.
