Some questions about a Collet Chuck
Home › Forums › General Questions › Some questions about a Collet Chuck
  • #383862
    Chris1234
      @chris1234
      Evening,
      I have to build a machine that cuts slots in something.
      It needs to cut a number of slots at the same time.
      My plan is to use several collet holders in bearings mounted into a platform, they would all be belt / chain driven.
      I'm wondering if the shaft on the collet holder below would press straight into a bearing or would it be a loose fit?
      Thanks.
      https://www.rdgtools.co.uk/acatalog/20MM-STRAIGHT-SHANK-COLLET-CHUCK-ER32-1268.html
      #26326
      Chris1234
        @chris1234
        #383992
        Martin Connelly
          @martinconnelly55370
          I have an ER32 and a smaller ER11 (I think) with nominal Ø16 shanks. As far as I can measure without a temperature controlled workshop and un-calibrated mics and Vernier callipers (real Vernier, not digital) they are parallel and consistently Ø15.98. However I may just have been lucky and some out there may be a bit more variable.
          Martin C
          #384014
          HOWARDT
            @howardt
            Can’t you use a single spindle and arbor to gang mill the slots or do you have to use slot drills.
            #384030
            IanT
              @iant
              Sounds a little bit like gang milling on a horizontal mill…?
              IanT
              #384043
              Chris1234
                @chris1234
                Hi, thanks for the replies, the shape of the slots needs to be as an endmill would make them, an extended circle. ie. two parallel sides and a radius at each end. So I can't use a single spindle unfortunately.
                I will order some collet holders tomorrow and try them, if they are not press fit then I will use bearing with grub screw (RA?).
                Thanks for your help.
                #384062
                  Posted by Chris1234 on 05/12/2018 19:11:06:
                  Loctite 'Bearing Fit' would [in my opinion] do a better job than a grub screw.
