Hi Guys
Can anyone out there help me, I own a kity Woodworking Machine and need to fit a new blade to my table saw.
The Trend saw blade I want has a 30mm diameter bore and it's plate thickness is 1.6mm (Trends part number is CSB/22048).
I need a reducing bush 30mm O/D with a 15mm I/D to suit the diameter of the arbor on my machine.
I think a bush 1.2mm thick should be suitable so it's slightly thinner than the saw blade, so the clamping plates will clamp the saw blade and not the bush.
Question: Is there anyone out there who could make me one of these bushes, obviously the hole in the centre of the bush will need to be concentric with the O/D otherwise I will end up with a very bouncy saw, not good for cutting wood
I've tried getting a bush from Bosch but they have now discontinued them and I don't know where else to try.
I'm happy to pay someone for their time if they can help me out.
Cheers
