Ceramic Ball Bearings
Home Forums General Questions Ceramic Ball Bearings
  • #25185
    michael howarth 1
      @michaelhowarth1
      #293481
      michael howarth 1
        @michaelhowarth1
        Not for the first time I am having a bit of an issue with allegedly stainless steel balls in a loco safety valve. May be just a bad batch……but has anyone tried out ceramic ball bearings in this sort of application? A quick Google of their properties seems to indicate that they would be just the job.
        Mick
        #293499
        richardandtracy
          @richardandtracy
          In one of LBSC's articles he suggests putting a ball in the safety, then giving it a sharp strike to bed the valve in. Not sure what would happen with a ceramic..
          Apart from that, could be a workable idea.
          Richard
          #293516
          julian atkins
            @julianatkins58923
            Hi Mick,
            Yes, excellent results with the ceramic balls on check valves. Am sure they would be just as good in a safety valve apllication..
            Cheers,
            Julian
            #293525
            Windy
              @windy30762
              I use stainless valve bodies and balls on my flash steamer and apart from a bit of dirt now and then they have been good.
              The one thing I always check are the stainless balls 316 some of the other stainless balls materials are more magnetic and get a dark gunge colour after a short run in my application.
              #293535
                Have you tried stainless balls from a good brand name bearing supplier such as SKF? Not all balls are created equal, specially those cheapies off the net or through intermediate suppliers for "hobby" use which sometimes seems to mean not the absolute top-of-the-line professional quality gear (with matching price of course).
                #293555
                HOWARDT
                  @howardt
                  Years ago used glass balls in place of stainless steel in high pressure check valves, 2500 psi. This was because the material passing through eroded the ball and the glass lasted much longer.
                  #293604
                  john carruthers
                    @johncarruthers46255
                    Edmund Scientific do ruby and quartz balls in various diameters, surprisingly cheap considering they are of optical surface quality.
                    #293611
                    martin perman 1
                      @martinperman1
                      The only issue I have with ceramic balls is that they are prone to pick up any impurities and end up with "crystals" growing on them from what ever is in the water stopping the valve from seating properly. The valves we use at work have to have the balls soaked in a mild acid to remove anything which has grown as a maintenance check.
                      Martin P
                      #293614
                      michael howarth 1
                        @michaelhowarth1
                        Thanks for those comments gents. It sounds as if they are worth a try.
                        Mick
                        #293616
                        michael howarth 1
                          @michaelhowarth1
                          John…..I have just had a look at the edmund scientiic site…..what am I looking for? Are they lenses?
                          Mick
                          #293620
                          Keith Long
                            @keithlong89920
                            Mick – look for "ball & condenser lenses"
