Valve timing
Valve timing
Home › Forums › General Questions › Valve timing
  • #205604
    Boiler Bri
      @boilerbri
      I managed to get air onto my Durham and North Yorkshire traction engine this evening. I set the eccentrics as described in the series of model engineer, 90 degrees to the crank.
      It runs ok but I am not sure if the timing is correct?
      Can some one explain what the slide vales positions should look like. We can only see one port at a time as the slide valve moves.
      Brian
      #24135
      Boiler Bri
        @boilerbri
        Stephenson’s motion
        #205625
          You would be better with the eccentric having a slight lead so 90deg plus 5-7 deg.
          Yes you should only be able to see one port open to the valve chest at a time, the other will be under the cavity to link it to the exhaust
          #205635
          julian atkins
            @julianatkins58923
            hi brian,
            if i can add a little bit more to jason's reply,
            if you have launch links the eccentrics must be advanced by an amount equal to the lap on the valve plus any lead. this is relatively easy to work out with launch links. i should imagine that for a traction engine there will be no lead and no pre admission in full gear, so all you have to do is advance the eccentrics by the amount of lap.
            with launch links, and depending on the amount of lap, the angle of advance in degrees may be more than that stated by jason. however i am applying miniature loco practice, and it may be that jason's figure is quite correct if there isnt much lap on your valves on your traction engine.
            however guessing the angle is an imprecise method and it can be worked out very accurately.
            if you use the 'sight' method for centralising the valve, a better method is to do this with air checking both leads and cut offs.
            cheers,
            julian
            #205697
            Boiler Bri
              @boilerbri
              Thank you for the replies. I will have look at it this weekend and see if I can improve things.
              Brian
