O rings – where to buy true inch sizes
Home › Forums › General Questions › O rings – where to buy true inch sizes
  • #204771
    Tony Martyr
      @tonymartyr14488
      I am making the beam engine to the 'Mary' design which calls for three different sized O rings of imperial sizes. Although listed as 'true inch sizes' on the web site of Exact Rubber they are no longer available.
      Can anyone guide me to a possible supplier – I have made O rings in the past from Gaco cord but never as small as two of the rings needed for the valve and piston rods
      Tony
      #24122
      Tony Martyr
        @tonymartyr14488
        #204776
        David Clark 13
          @davidclark13
          Try Radiospares. They used to do reasonable price packets of silicon o rings.
          #204778
            Do they need to be true imperial size, I would have thought the engine specifies Nominal sized BS O rings
            Most of the ME suppliers will have BS spec rings, post the sizes are given on the drawings, should not be hard to look up the BS number
            #204890
            Johnboy25
              @johnboy25
              Try www.mantek.co.uk in Aldershot Hampshire. They sort my requirement out ok.
              Usual disclaimer.
