You speak as if it is already mounted so the advice to leave as it is an try to get the legs on the stand all sitting on the floor is good. The speed 10 and ml 10 are pretty solid beds as they come and the tray is more likely to distort than the bed.
I wonder about comments concerning shimming and bolting down beds to avoid distortion. I feel it came from a time when lathes were mounted on very rigid cast iron stands that might even weigh more than the lathe.
There is a simply way of mounting lathes in a stress free way without shims etc. It just needs longer bolts of the same size that the lathe normally needs for mounting. Fasten these to the tray or frame thread pointing up, fit nuts and tighten. I add washers. Fit another nut loosely, a penny washer ideally then place the lathe on them. Adjust each of the support nuts to that the lathe sits evenly on them. I do that by just adjusting lightly finger tight. Fit a washer and another nut to each and lightly tighten down. Maybe use nylocks. To be honest I don't and just do the top nuts up finger tight. They don't work loose.
Some lathes come with an adjustment just like this. The mounting holes in the lathe are threaded and accept a sort of flanged bolt with a hole through it. This is used to get the lathe sitting evenly and then it's simply bolted through.
Myford made a casting for these lathes that accepted the lathe and the motor assembly. On some of these lathes the motor assembly is just bolted to the tray. You might need to use the same arrangement on the motor assembly if you don't have the casting in order to get the belt tensioning to work correctly.
Lathes can also be mounted on items like these, there are a lot of different sizes available.
Much cheaper than lathe resilient mountings and will achieve the same thing. Personally I don't think they are much use unless they isolate any vibrations from the motor to the lathe itself.
Edited By John W1 on 30/07/2015 15:43:10
