Painting aluminium
Painting aluminium
Home › Forums › General Questions › Painting aluminium
  • #198409
    Nick_G
      @nick_g
      Hi guy's
      This is really not a ME question as it's concerning my motorbike.! Although there are some very switched on guy's on the motorbike forums I feel I will get a more straightforward answer here.
      I presently have the wheels off my bike for a friend of mine to fit new tyres onto. The sliders on the front suspension are looking a bit tatty. So while the bike is jacked up I have removed the stanchions and sliders with a view to giving them some paint. I now have them down to the bare aluminium.
      I know that an acid etch type primer is required initially. But my question is once the etch primer is cured is it then best to follow with a 'normal' primer before the finish coats or can I go straight to that stage.?
      Thanks, Nick
      #24007
      Nick_G
        @nick_g
        #198410
        Mark P.
          @markp
          I would put normal primer over the etch prime if I were you.
          Mark P.
          #198412
          SarahJ
            @sarahj
            Hi Nick, I've used U-Pol Acid etch #8 on a few projects now and never had to use another primer. The product data and data sheet are on the link below: http://www.u-pol.co.uk/product-cat/35/acid%238™-acid-etch-primer.htm
            #198413
            SarahJ
              @sarahj
              #198415
              Alex Collins
                @alexcollins55045
                It depends on what you want to put on as a top coat.
                I always put a single coat of primer on the top of the etch primer.
                That makes sure it'll stay good in my book and adds very little cost.
                #198420
                Robbo
                  @robbo
                  I've used U-Pol acid etch #8 on aluminium and galvanised steel, followed it up as soon as dry with a couple of coats of topcoat gloss and it has made a great job . As the saying goes "sticks like s**t to a blanket"
                  #198429
                    Etch primer is primer. No need to put primer over primer.
                    #198434
                    Steve Pavey
                      @stevepavey65865
                      Depends on the type of etch primer used. If you use a zinc chromate etch primer it is only put on as a very thin mist coat. It will need a conventional primer applied on top to give some film thickness so it can be flatted ready for a top coat. Some of the two-pack primers are also meant to be used as a base for an epoxy primer.
                      Some information on primers here **LINK**
                      #198436
                      richardandtracy
                        @richardandtracy
                        My next-door neighbour at home is a coachworks. The owner uses etch primer then normal undercoat that goes straight on steel bodywork, then a top coat when he has aluminium panel Landrovers to restore.
                        Richard
                        #198568
                        Ian S C
                          @iansc
                          Apparently the stuff used today in aviation is Strontium Chromate, this seems to have superseded Zinc Chromate.
                          Ian S C
                          #198569
                          Ajohnw
                            @ajohnw51620
                            I did an entire kit car once. 1st thing was a scratch brush, 2nd an aluminium etching primer and then what ever paint.
                            The scratch brush was about 3" dia on a 5in angle grinder and left a matt finish.
                            No problems with the paintwork over the 6 years or so I knew where the car was and some of it was pretty flexible. Plenty of problems with the gearbox mountings. Tuned up engine and they were made of boiler plate.
