Power Advice
Power Advice
Home Forums General Questions Power Advice
  • #127492
    Alan .204
      @alan-204
      We have just got our new machine all cleaned up and ready to go but now we are pondering on the best way to run it, it's three phase and we only have 240 the motors could be rewired to run of inverters but there are three of them 1hp-and .75hp and .5hp can you run three motor's of one inverter? we don't need variable speed as the machine is a surface grinder, do we go for a phase converter advice please, just been shouted for my tee.
      Regards Alan.
      #22784
      Alan .204
        @alan-204
        #127494
        Robbo
          @robbo
          For ease of use, and as you don't need the facilities of a VFD, then a phase converter would be the way to go. And you can use it for other machines you may get, whereas the inverter would be dedicated to one machine/motor.
          You can run more than one motor from a VFD(inverter), by wiring them piggyback fashion, but they both run at the same time, and I think trying it with 3 motors is too much.
          Hope you enjoyed you tea (Facebook and Twitter intruding here)!
          Phil
          #127497
          Alan .204
            @alan-204
            Thanks Phil that's pretty much what i thought but thought I had better ask in case there was something else I didn't know about.
            Al.
            #127513
            Alan .204
              @alan-204
              Hi Phil I don't know what size phase converter to look for to run these motor, what size KW converter do you think I should look for, I'm wondering if it would need to be a bit bigger in order to start the older type motors, what do you think, by the way I haven't found out yet how you convert KW in to HP.
              Al.
              #127529
              roy entwistle
                @royentwistle24699
                746 KW is 1 HP
                Roy ( or it was at Worsley Tech 65 years ago )
                #127534
                roy entwistle
                  @royentwistle24699
                  Slip of the old grey cells 746 W = 1 HP
                  It's allowable at 80
                  Roy
                  #127535
                  Les Jones 1
                    @lesjones1
                    Roy.
                    I don't think 746 KW was ever equal to one horse power. I think 746 KW has always been equal to1000 HP. If you are right I will have to get my mains supply upgraded to 3000 amps and I will not be able to afford the cost of running my lathe.
                    Les.
                    #127538
                    Trevorh
                      @trevorh
                      Kw x 1.341 = HP
                      regards
                      #127733
                      Robbo
                        @robbo
                        Well done Roy, I am happy to see that I am not alone!
                        Have always used rule of thumb that 750 watts equals 1 HP, near enough for our purposes and easier to reckon for the more elderly like Roy and I.
                        Converters usually have a lower and upper range of output/ motor size in HP/watts, so I should reckon on one with the total motor HP (2¼ HP,- about 1700 watts  as the lower figure, that allows for the older motors requiring a bit more.
                        Fractional horsepower motors, especially older ones, never translate HP to watts exactly, I have found.
                        Phil
                        Don't know how that smiley got in there, it's supposed to be close bracket, but it won't go away.
                        Edited By Robbo on 24/08/2013 09:58:51
                        Edited By Robbo on 24/08/2013 09:59:44
                        #127737
                        Russell Eberhardt
                          @russelleberhardt48058
                          Posted by Robbo on 24/08/2013 09:58:08:
                          Just put a space in front of the close bracket symbol.
                          Russell
                          #127741
                          The Merry Miller
                            @themerrymiller
                            Trevorh,
                            Are you sure about that Trevor??
                            Len. P.
