Amolco milling attachment
Home › Forums › General Questions › Amolco milling attachment
  • #22300
    Kevin F
      @kevinf
      #102638
      Kevin F
        @kevinf
        Hi, has anyone used one of these milling attachments on a Myford lathe? One has come up for sale locally at a reasonable price ,I already have a vertical milling slide ,is it worth buying a milling attachment to make milling on a lathe easier ,also does it fit all myfords inparticularly the ml4?
        Thanks Kev
        Edited By Kevin Fenrich on 03/11/2012 14:51:39
        #102664
        joegib
          @joegib
          Hi,
          I have an Amolco attachment with a column base fitting for Myford ML10. As far as I know the makers only ever made base fittings to suit the ML7, the Super 7, the ML10 and the Boxford 9" lathe range. So, each machine has a different base. You can see photos of the attachment here:
          Amolco
          One of the photos shows the base for an ML7, I believe. The base is mostly flat with a central longitudinal tongue designed to fit between the shears of the ML7. The whole assembly is secured by 2 vertical screws through the base and attached to 2 keeper plates that tighten up against the flat undersides of the shears. It's fairly critical that the tongue be well-fitted to the slot between the shears else the base/column may shift under cutting pressure.
          I assume your target attachment is likely to have an ML7 base fitting — this you'll need to establish, of course, and report back. Whether you can fit it to your ML4 will depend on 2 issues:
          (1) What the measurement between the shears of your ML4 is on the one hand, and a standard ML7 on the other. You should determine this measurement for your ML4 and report back. Maybe other members who have standard ML7s could kindly state what this value is for their machines.
          (2) The other issue concerns the end profile of the slot between the shears. The underside of the ML7 shears is machined such that the end profile forms, in effect, a T-slot. This is what allows the Amolco keeper plates to lock the assembly. Does your ML4 have this feature and if so, what is the full width of the space beneath your machine's shears and are their undersides machined? Again, maybe ML7 owners could state this dimension for their machines.
          As regards the attachment itself, the practical limit of the area you can mill is somewhat less than the area of the crosslide. Interpose a vice and it's even less but if the model components you plan to mill are fairly small scale, you'll do fine. Having said that, I seem to remember machining a 4" x 3" angleplate (using a solid vice) and rough machining a Stent 'L' bed at 2 settings, though the finish machining was done on a proper milling machine. The nice thing about the Amolco was that it provided what basic hobbyist milling machines don't — autofeed via the lathe leadscrew!
          If you get back to us with the measurements mentioned above we can assess whether the attachment can be adapted to your ML4.
          Joe
          Edited By joegib on 03/11/2012 18:21:51
          #102677
          Kevin F
            @kevinf
            Total width of the shears is 74mm the width inbetween the shears is approx 20 mm
            #102711
            joegib
              @joegib
              Hi Kevin,
              Sorry, I don't think I made myself clear. Please find below a rough picture of the end profile of an ML7 and how the Amolco attachment is secured by 2 keep plates to the undercuts beneath that model's shears:
              You've stated what the 'A' dimension is. We need to know what the 'B' dimension is for your ML4 as this will show how much width/area the keep plates will be able to seat on.
              Since last posting I've had a look at an ML4 document on the Myford Yahoo Group — see picture:
              — and there doesn't seem to be much of an undercut at all beneath the shears. If that's right, then I don't think that an Amolco attachment with an ML7 base will be easily adaptable to your machine.
              The above picture is taken from this document:
              ML4
              Joe
              #102713
              joegib
                @joegib
                Just as an afterthought, I note that your ML4 has dovetail-sided shears. As it happens, the ML10 also has a broad single dovetail shear whose width is 75mm, pretty close to your dimension of 74mm. If, by chance your target buy has an ML10 base then it should, more or less, fit your machine straight off. (Sorry, my machine's not for sale).
                frown.
                Joe
                #102727
                DMB
                  @dmb
                  joegib,
                  Re your post on 4/11@0910. Google says the link given by you is broken.
                  Kevin F
                    @kevinf
                    I've created an album for my ml4 lathe ,if you look at the pics you can see that  unless I modify the base plate of the amolco milling attachment it won't fit,the base plate that comes with the milling attachment is for an ml7
                    Edited By Kevin Fenrich on 04/11/2012 12:03:55
                    #102741
                    joegib
                      @joegib
                      Posted by DMB on 04/11/2012 11:13:56:
                      joegib,
                      Strange, it worked when I tested it after posting. Anyway, I've uploaded the file elsewhere — hopefully, it works here:
                      ML4 new link
                      Joe
                      #102745
                      joegib
                        @joegib
                        Posted by Kevin Fenrich on 04/11/2012 12:00:19:
                        Ah, that's a shame. I've also noticed that the ML4 has a cantilever bed. The Amolco must weigh around 60-70lb so that's quite a lump to hang on the end of what's in effect an outrigger designed to support only a 10-20lb tailstock. At worst, this could distort the bed, nullifying any hope for accurate work. This is different to the ML10 design which has a box bed with support screws directly under the tailstock. You could maybe reduce the effect by moving the attachment more towards the headstock, hence providing better support. But this is all speculative if you don't have the facilities to machine a sub-base matching the ML4.
                        Joe
                        Edited By joegib on 04/11/2012 13:32:32
                        #102746
                        MICHAEL WILLIAMS
                          @michaelwilliams41215
                          The Amolco and many similar types of milling attachments including DIY ones are far better fitted semi permanently at the back of the bed about half way along .
                          Doing this means that for most of the work likely to be done the milling attachment is in place ready to use AND the basic functions of the lathe are unaffected and also ready to use .
                          Some further advantages are that quite big workpieces can be milled and a proper boring table can be used .
                          On ML4 some DIY brackets needed but no problem . Ideally there will be some adjustment so that you can move milling attachment in and out to address different types of work and further adjustment to push or swing attachment out of the way altogether .
                          Regards ,
                          Michael Williams .
                          #102762
                          Kevin F
                            @kevinf
                            Posted by joegib on 04/11/2012 13:31:04:
                            Joe
                            I have use of the facilities to mod / make a sub base , but is it worth the extra work to make it fit ?
                            if you can answer that question with a positive yes then that is good and it's worth the effort for me to make a new sub base , there is another question how good are these milling attachments ,compared too a small hobby miller ?
                            I'm in negotiations at the moment,there is no tooling with the attachment just the attachment itself ,how readily available are collet chucks ect
                            Edited By Kevin Fenrich on 04/11/2012 17:02:52
                            #102763
                            Kevin F
                              @kevinf
                              Posted by MICHAEL WILLIAMS on 04/11/2012 13:50:48:
                              Doing this means that for most of the work likely to be done the milling attachment is in place ready to use AND the basic functions of the lathe are unaffected .
                              the only problem with making the attachment semi permanent would be the positioning of the tail stock in respect of the cross slide for milling purposes
                              #102774
                              MICHAEL WILLIAMS
                                You'll have to explain that one – its beyond me .
                                #102860
                                joegib
                                  @joegib
                                  Hi Kevin,
                                  Here's an outline sketch for a set-up that should allow you to use an ML7 type Amolco with your ML4:
                                  Note that:
                                  1. I've designed it so that you can use the ML7 type fitting as-is i.e. no butchery required. That way you can sell on the machine intact if you later get a milling machine.
                                  2. The new sub-base replicates the ML10 set-up whereby the unit base is locked against the bed dovetail Vees by means of a rising Wedge/Gib Strip arrangement. In the ML10 set-up the cap screws are actually on top of the base and pull up the wedge. Here I've reversed the arrangement so that they push up the wedge from the bottom. A little less convenient perhaps but again that means you don't have to machine the ML7 base.
                                  3 The ML7 base is locked to the sub base by the existing keep plates. You'll need to machine 2 rectangular recesses in the underside of the sub-base to accommodate the keep plates — it's important that these are below the support surface so they don't mar your lathe bed shears when fitting the Amolco. On the other hand it doesn't matter if the lock-nuts project beyond the support surface because these are narrow enough to fit between the bed sheers.
                                  4. The sub-base can be made from a piece of cast iron 100mm x 140mm x 30mm. This will raise the machine a little higher than the standard base but shouldn't affect normal operation.
                                  5. I'm still a little concerned by the cantilever bed. If you go ahead with the project I'd recommend that you set up a jackscrew arrangement to give additional support to the end of the bed.
                                  As regards whether the project's worthwhile, well it's definitely significantly better than a vertical slide. But that still leaves you with a fairly small work envelope compared with even quite modest standalone mills. Bear in mind that a limiting factor is the travel of your crosslide (which appears to be appreciably shorter than the ML10 'long' crosslide on my machine).
                                  You can't regard this sort of set-up as a cheap substitute for full milling capability. I suspect for most of us who've had these machines, it's a stop-gap on the road to a standalone mill.
                                  Joe
                                  Edited By joegib on 05/11/2012 15:02:08
                                  #102891
                                  joegib
                                    @joegib
                                    Hi Kevin,
                                    A few final points:
                                    1. I think perhaps you misunderstood Michael's point above. He's referring to the arrangement used in some 'combo' machines whereby the Milling Head is mounted on the back of the lathe via a stout bracket. You can see the arrangement in this Emcomat 7:
                                    Emcomat 7
                                    This doesn't interfere with the normal use of the lathe. There, of course, the bracket is a manufacturer's designed component. To use this arrangement you'd need to fabricate the bracket.
                                    2. The Amolco spindle nose is broadly the same as the Myford ML7/ML10 spindle nose. It is bored MT2 and will therefore accept MT2 Morse collets which are secured by a nose nut. Ideally your target machine should come with the Amolco-supplied nut but if not, the Myford/RDG nut (£34) will fit. I'd recommend you use MT2 collets as they are quite cheap, are more rigid in this set-up and above all, don't eat up valuable headroom (as compared to an ER MT2 chuck, for instance). You only have 8"!
                                    Joe
                                    Edited By joegib on 05/11/2012 18:43:43
                                    #102896
                                    KWIL
                                      @kwil
                                      Gentlemen, whilst you may well be happy with quoting the Myford Shear dimension in mm, they are nevertheless imperial from the start and an exact dimension. Your stated mm are but an approximation.
                                      #102917
                                      Kevin F
                                        @kevinf
                                        Thankyou to everyone who has replied on the thread much appreciated, not only has the replies been of great help to myself but I'm sure other members in a similar position can gleen some info from here.
                                        id like to apologies to Michael Williams as I misunderstood his post, thankfully joegib clarified Michael's post , secondly kiwi my diamentions were approx , I'm aware that Myford's in general are imperial, so to clarify 74mm would be approx 3inches and 20mm would be 3/4inch I measure these diamentions with a steel rule they were only ment as a guide .
                                        thanks Kev.
                                        #102941
                                        joegib
                                          @joegib
                                          KWIL,
                                          Now you've got me confused. Philosophically, all measurements are approximations. I dare say that the sniffier NPL scientists would dismiss the output yielded by your finest micrometers as mere appoximations. It's all a matter of degree (and the context of the discussion).
                                          It's not as though I'm designing and building the sub-base for Kevin's machine. If he went ahead plainly he'd have to design the sub-base by reference to the actual dimensions of his lathe and the Amolco unit he acquired. But even then, the only fairly critical consideration is that the Wedge/Gib Strip be sized so as not to bottom-out (or top-out?) before lock-up against the shears is achieved. Indeed, the very nature of the wedge mechanism allows some significant flexibility in that regard.
                                          Yours approximately (it's 6am!)
                                          Joe
                                          #102943
                                          Ady1
                                            @ady1
                                            If possible I would leave the original miller base 100% intact and make an independent ML4 adaptor plate
                                            As you get more serious about this hobby there is a a high probability that you will upgrade from an ML4 and experience one of those "OMG What the heck did I do that for?!" moments
                                            You are always better off making adaptors for original equipment instead of physically adapting original equipment, even if it takes longer to do
                                            most of the old stuff is now irreplacable and large relatively rare ml7 accessories have a high resale value
                                            Messing up the base of your Amolco attachment means you have painted yourself into a corner
                                            An adaptor plate leaves you with all the options you had to start with
                                            EDIT
                                            I see that Joe has very kindly drawn you this solution
                                            The solution I would use if it's possible with an ML4 is to use the tailstock base plate, preferably to buy a second tailstock unit
                                            Then remove the upper half and try to use the tailstock base plate which already fits snugly to the bed
                                            EDIT2
                                            It doesn't look like this will be possible in your case
                                            if they do any ML4 tailstocks like the Myford M series then you'll see my logic, the top and bottom can come apart, leaving the base available for other uses
                                            Edited By Ady1 on 06/11/2012 08:12:02
                                            #102944
                                            Ady1
                                              @ady1
                                              Myford did eventually offer a semi decent tailstock with "a separate sole plate" because their original tailstocks were pretty rubbish
                                              If you can get hold of one of these it would probbly make things easier
                                              The weakness of the original Myford tailstock, as fitted to the ML1, ML2, ML3 and ML4 lathes, was eventually acknowledged by the factory which then offered the much-improved version shown left and below. This featured heavier castings, a thick gib block to set the alignment (replacing the flimsy side plate) and a separate sole plate that allowed the unit to be set over for the turning of slight tapers.
                                              Edited By Ady1 on 06/11/2012 08:29:56
                                              #102947
                                              Ady1
                                                @ady1
                                                Looking an the piccy above It looks like you have a very thin bed, ML4s were only ever intended as entry level hobby machines
                                                The shears on a 3.5" Myford M series are 110mm, almost 50% bigger, which is a lot more metal
                                                I think if you plonk a full size milling machine attachment onto your wee lathe then it's going to struggle
                                                Good Luck tho, it's all part of the fun
                                                Edited By Ady1 on 06/11/2012 09:00:29
                                                #342736
                                                Jon Cameron
                                                  @joncameron26580
                                                  Firstly sorry for resurecting such an old thread. However i will soon be fitting an Amolco milling attachment to my ML4.
                                                  It has been donated to me by a friend and after some discussion with him it was decided to make an adaptor plate. The pics posted above show the end of the lathe closed off, however inside the casting of the bed there is the same profile as the ML7 has albeit smaller. This means that the original foot will be mounted into an andaptor plate with M6 cap head screws securing it to the base of the original foot. the original clamping method will be employed to hold it to the ML4 bed, but new clamps will be made to allow for this to happen. as the undercut on the ways is narrower.
                                                  Below is the proposed adaptor plate and how it will fit onto the ML4. The points raised about the cantilever bed are valid, and this will limit the fuction slightly as it will need to be brought more to the center of the lathe to maintain ridgidity. Not all the dimentions are shown here, this is just so as it can be visulised. CAD drawings done by Sandy.
                                                  #342754
                                                    @mike89748
                                                    I have an Amolco milling attachment, and when I had a Super 7B the Amolco, in conjunction with a long cross slide and power cross feed the combination looked after all of my relatively light milling requirements. I still have the Amolco which, attached to a big chunk of steel plate and with an X-Y table, also serves for light milling. Problem is that the X-Y table is metric, while the vertical movement of the milling head is imperial. Keep meaning to get some DRO kit, but never seem to get around to it, so the calculator is always handy on the bench!
                                                    #342799
                                                      Note what Mike said about "light" milling requirements.
                                                      I used to have a ML7 and used a Rodney milling attachment on it. maybe i was heavy handed, taking 0.020" cuts, but I did not like the way that it shook the ML7. I do not imagine that the ML4 is any more rigid, so would advise taking only light cuts.
                                                      That is why I went out and bought a Mill/Drill, and there are times when I can see the vice and machine flexing.
                                                      Not in the same league as the Cincinattis that i used as an apprentice, but they weighed about forty times as much!
