Amolco milling attachment
Home › Forums › General Questions › Amolco milling attachment
Viewing 2 posts - 26 through 27 (of 27 total)
  • #342836
    Jon Cameron
      @joncameron26580
      Thanks Mike and Howard, it wont be pressed into service until i go pick it up with newly machined adaptor plate.
      It also wont be taking heavy cuts, when i got the ML4 i went gently does it until it rattled around then i knew i had reached what i was comfortable with, the ML4 will take upto 40 thou roughing cuts, but i tend to feed around 10thou a time on the dial (20thou off dia).
      Ill treat the mill much the same, ramp it up from a couple of thou till i feel vibrations then wind it back. Im not doing it for industry just for a hobby so ill happily take my time.
      Id like to have a larger lathe, and a knee mill, but space constraints and costs are all limiting me to a much smaller setup.
      Still looking forward to making some tooling to go with the setupsmiley
      #342949
      Meunier
        @meunier
        I was dissuaded by my chum "it's a compromise" from buying one at Mole's shop in Watford in the late '60s/early '70s but did fall for a nice Tripan QCTP and some toolholders which are still doing good service.
        DaveD
