Multi tool sharpening
Home Forums Workshop Tools and Tooling Multi tool sharpening
  • #18004
    Dave Bond 1
      @davebond1
      #226428
      Dave Bond 1
        @davebond1
        Any easy ideas of how to sharpen one of these saw blades?
        http://www.screwfix.com/p/bosch-plunge-cut-saw-blade-28mm/60742
        I was thinking of a 60 degree diamond file and carefully doing it by hand. Anyone got any better ideas?
        When they get blunt the teeth wear quite quickly, so a shaped fine grinding wheel may make everything much quicker.
        #226434
        Vic
          @vic
          £21.99, I'm not surprised you want to resharpen it! How do they come up with these prices?!
          #226438
          Martin Kyte
            @martinkyte99762
            Are they not hardpoints.? If so all you may end up with is sharp soft teeth. However your small diamond file would be the way to go in my opinion.
            regards Martin
            #226449
            John Hinkley
              @johnhinkley26699
              Well, if you don't mind a pattern blade and a bit of a wait, there are blades available on eBay for 99p upwards. Not 28mm, I grant you, but 32mm and 20mm varieties. I assume it's for metal and/or wood. At that sort of price, they can be classed as disposable, I reckon.
