Multi Link Belting
Multi Link Belting
Home › Forums › Workshop Tools and Tooling › Multi Link Belting
  • #221498
    martin perman 1
      @martinperman1
      Gentlemen,
      Yesterday I bought a metre of the above for a project and I have a question, when I used this many years ago I seem to remember that there was a preferred direction of travel, am I correct and if yes which direction for the belt.
      Martin P
      #17962
      martin perman 1
        @martinperman1
        #221508
        mark costello 1
          @markcostello1
          I believe that if You look at the belt, going way closes up the bottom of the linl, and the other way round opens it up. If You have forward and reverse speeds You will only lose 1/2 of the time!smiley
          #221517
          Speedy Builder5
            @speedybuilder5
            This is what STEAMDAVE wrote about Myford Link belting:-
            This is the direction link belts should be fitted
            The Emerald Isle
            Others have said to turn the belt inside out as it is easier to make the joint.
            BobH
            #221519
            John Haine
              @johnhaine32865
              If you buy the ones with red fibre links they have little arrows printed on them…
              #221522
              martin perman 1
                @martinperman1
                Gentlemen,
                Thank you, the belting is to be used to replace a standard V belt on a hamworthy compressor set I own and show, to replace the original would require taking the engine and pump apart as they are directly coupled.
