Spindex End Mill Sharpening
Home › Forums › Workshop Tools and Tooling › Spindex End Mill Sharpening
  • #217086
    Vic
      @vic
      http://youtu.be/9E1hzG8R9b8
      Edited By Vic on 19/12/2015 17:35:19
      #17930
      Vic
        @vic
        #217101
        Dave plus / minus 40 thou
          @daveplusminus40thou
          I watched this recently Vic, not so sure about the grinding wheel in the mill (!), the safety aspects make me cringe and watch with one eye closed. Am making a modified version of Mike Checkley's vice end stop from the last issue of MEW then use the spindex in my surface grinder – plan to use a section of hacksaw blade as the flute "stop", can then rotate and onto the next flute without any changes (the blade should flex out of the way).
          John Stevenson 1
            @johnstevenson1
            I originally posted this around the year 2000.
            It's a staged shot and I never made one but I know a few who have. Basically, chequebook engineering by buying a Spindex, one of those cheap compound tables and a bench grinder.
            Or utilising any of the above if already owned.
            The Spindex sits on a piece of angle iron which needs remaking as a proper bracket.
            The house brick supporting the grinder is optional.
            Seriously something like this could be cobbled up easily in a weekend instaed of the statuatry 7 years to work up the enthusiasm to build a Quorn.
            #217103
            Martin Connelly
              @martinconnelly55370
              A hacksaw blade may be too stiff. A feeler gauge blade may be a better option if your flute stop is a short one.
              Martin
              #217139
                Posted by Dave plus / minus 40 thou on 19/12/2015 21:33:07:
                Prof. Chaddock's 'Building the Quorn' has a photo of the head being used on a vertical mill to make a poor man's surface grinder. He also suggests using double sided sticky tape as a substitute for a magnetic chuck…
