gr 8.8 ht bolt steel which carbide tip
Home Forums Workshop Techniques gr 8.8 ht bolt steel which carbide tip
Viewing 25 posts - 1 through 25 (of 53 total)
  • #565655
    brian jones 11
      @brianjones11
      Can anyone suggest how to select a proper carbide tip (10mm shank) for turning gr8,8 steel on a Myford
      I have struggled with ones that came with those tool sets on EB but of course I am deeply suspicious about the quality of the tips – they will cheat you if they can , its a national sport)
      I found a 60deg diamond tip seemed to loose its edge quickly and I ended up with a poor cut finish on 20mm dia taking 50mu cut at 1500 rpm
      These carbide tips are still a bit of a mystery to me but I couldnt touch this steel with HSS
      Any advice please
      Brian
      #16323
      brian jones 11
        @brianjones11
        #565663
          Tickling it with 0.05mm cuts is not the way to use inserts, for a TCMT try to cut at least 0.25mm, if you want to take finer cuts to sneak up on a finished size then use the ones intended for non ferrous which are TCGT
          The shank of your tool won't affect the tip much, it's the size of tip that your 10mm shank tool takes that will affect overall size then the material dictates most of the rest
          #565684
          Anonymous
            Posted by brian jones 11 on 05/10/2021 15:19:39:
            …..couldnt touch this steel with HSS……
            Something wrong there. Here's the head of a 12.9 M12 bolt I just machined with a 5/16" square HSS knife tool that just happened to be lying next to the lathe:
            Running at 540rpm with a feed of 4 thou/rev and DOC of 10 thou. The finish looks worse than it is real life. A few measurements gave an average surface finish of 1um Ra, which is about as good as I get when turning.
            The tool sets from EB can go in the round filing cabinet. There are two rules for buying cutting tools:
            1. Don't buy cheap cutting tools – applies to everything from files and hacksaw blades to coated carbide endmills
            2. See rule 1
            Perversely the rules apply even more to smaller lathes as they don't have the power and rigidity to overcome poorly ground or less than sharp tools.
            In general I'd agree with JB regarding carbide inserts. They can create good finishes with small DOC, depending upon the material, but for carbon steels they prefer more like 10+ thou DOC and high surface speeds.
            #565685
              Never tried to machine an 8.8 bolt before, so in the interests of science:
              I skimmed the top lip with a square insert, an interrupted cut bouncing off the hex head. Tough test on tough stuff, but carbide chewed into it reluctantly at 1900rpm without breaking. The motor is 1100W, but it wasn't working hard. Didn't remove much metal because I bought the bolt for a proper job and didn't want to spoil it.
              8.8 bolts are now on my 'difficult but possible' list. I'd rather work with machinable steel!
              Edited By SillyOldDuffer on 05/10/2021 17:23:32
              #565689
              Anonymous
                Posted by SillyOldDuffer on 05/10/2021 17:23:09:
                …8.8 bolts are now on my 'difficult but possible' list….
                Better not try 12.9 then!
                What was the provenance of the bolt? My experience of buying import tooling is that the SHCS fitted are made of cheesium, but may be some of them are tougher than expected? I don't worry about shortening bolts with a hacksaw when required.
                #565690
                brian jones 11
                  @brianjones11
                  I had to trim down an m24 bolt to a bit of 19mm shank so I could mount it into my collet
                  It wasnt a happy experience and I am not versed in carbide use but the surface finish was more like it had been smeared but i got my OD after a while. Its pushing Maureen to DOC 0.5mm. I kept think the tip was blunt – what it felt like – then I suspected the PRC tip of course
                  gr8.8 is tough stuff I didnt dare try HSS
                  but the question is, where to get a reliable tip for the job – there is soooooooooo much bs out there it leaves you totally confused
                  Edited By brian jones 11 on 05/10/2021 17:34:58
                  #565697
                  Ady1
                    @ady1
                    I've never got it to cut nicely, it always kind of deforms as you remove material and you get a lot of heat
                    Edited By Ady1 on 05/10/2021 18:20:01
                    #565698
                    Old School
                      @oldschool
                      I use 8.8 and 12.9 regularly sharp hss works well and if you want a really good finish do as Jason B says. Use good quality bolts as a source of material and the same goes for the inserts if you use them.
                      #565703
                      old mart
                        @oldmart
                        8.8 is only one step up from a gutter bolt in strength and hardness, so should be easy with anything you try.
                        #565704
                          Well at great expense I've sacrificed an 8.8 bolt (screw actually) of unknown parentage and taken a few video clips.All carbide at approx 1130rpm and 0.4mm (0.015thou) DOC All on a far eastern benchtop hobby machine. In order of appearence:
                          CCGT 060202 @ 0.04mm/rev (0.0015thou)
                          CCMT 060202 @ 0.04mm/rev
                          CCGT 060208 @ 0.04mm/rev
                          CCGT 060208 @ 0.08mm/rev (0.003thou)
                          CCGT 060208 @ 0.02mm/rev best finish but lost that bit so will post finish tomorrow
                          Lastly a random HSS bit not even on ctr height at 600rpm and 0.02mm/rev
                          Sorry about variable focus the moving chuck and swarf were confusing the camera but you get the idea.
                          have a look at APT, they sell inserts in two if you click on hobby use the CCGT inserts came from them, CCMT is Kennametal.
                          #565707
                          bernard towers
                            @bernardtowers37738
                            8.8 and better is absolutely OK to machine with HSS, your turning speed looks a tad high.
                            #565711
                            DC31k
                              @dc31k
                              I wonder if it is worth noting that 'Grade 8.8 steel' as such does not exist.
                              Fasteners are graded as 8.8, etc. but you cannot buy steel stock in this manner.
                              Maybe someone who knows the grades could give us an approximate comparison of bolt grades and steel grades.
                              Thanks.
                              #565712
                              Dave Halford
                                @davehalford22513
                                The simple answer is stop buying woodworking quality 200mm blanks
                                #565718
                                Nick Wheeler
                                  @nickwheeler
                                  I think the problem with turning down bolts is the the thread, not the material. Once you get past that, there's no problem. So a deep cut that takes off most, if not all, of the thread is the way to go.
                                  #565723
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Posted by DC31k on 05/10/2021 19:47:59:
                                    Thanks.
                                    Hi DC21k, maybe the scan below may help.
                                    Regards Nick.
                                    #565725
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi, this may also be of interest.
                                      Regards Nick.
                                      Edited By Nicholas Farr on 05/10/2021 21:30:11
                                      #565726
                                      DC31k
                                        @dc31k
                                        Thanks for the scan.
                                        Looking around, it appears that a Grade 8.8 bolt is roughly equivalent to EN19 or 4140 steel. The steel has a similar ballpark UTS but its yield strength is lower. Were EN19 a bolt, it would be graded approximately as 8.6 rather than 8.8.
                                        #565733
                                          It is worth noting. The Grade defines the strength of the fastener, which could be made of any suitable high-tensile steel. The cutting properties of any given bolt depend on the alloy it was made from, so how well it machines is in the lap of the gods.
                                          Whatever high-tensile steel meets the fastener spec will do. One source suggests most modern 8.8 bolts are made from Boron Steel – basically mild-steel with a dash of Boron in it. The resulting alloy is cheap and strong but it doesn't machine well, and it welds badly.
                                          If a Grade 8.8 bolt cuts OK with HSS, it's not made of Boron Steel. When HSS fails, try carbide!
                                          Bolts being made of different steels probably explains why people are reporting different results. My bolt gave carbide such a hard time I don't think HSS would cut it, but I'm prepared to believe HSS would be OK on other 8.8 bolts. I've had such bad experiences machining unknown alloys I avoid scrap, instead buying in metal I know is good to machine.
                                          Circlip
                                            @circlip
                                            Used to "Make" M16 LH thread allen screws from standard M16 on machine breakdowns. Screws/bolts had enough plain shank under the head to achieve this. NEVER used a carbide to do this, plain old HSS and ALWAYS got an excellent surface finish.
                                            Regards Ian.
                                            #565773
                                            brian jones 11
                                              @brianjones11
                                              Well JB if I had obtained anything like the results you showed on your vid, I wouldnt have posted this thread
                                              I have formed the simple idea that using carbide
                                              a) the tips are not sharp as per HSS, they are deliberately rounded slightly becasue a sharp edge in carbide would quickly chip and fail, so rounding gives better strenght
                                              b) because of a) above using carbide is like having to punch through a tough thin skin on the work piece to get through to a softer core which can be cut properly. Its counter intuitive to HSS viz with hacksaw you dont put more pressure and saw faster when you feel the blade is blunt
                                              The pic below shows my poor results, note the ridges and how the surface appears smeared like its been rubbed by the tool
                                              I can only assume that the tool tip with pressure reaches a high surface temp that softens the skin and lets mtl be rubbed off below – what an appalling thought
                                              and this was with a new insert
                                              I dont know what insert code I was using cos I only bought a set of tools
                                              https://www.ebay.co.uk/itm/133809788614?hash=item1f27af56c6:g:JmoAAOSwDD5g5DuQ
                                              the code wasnt specified
                                              As you can see its the worst kind of rubbish work and if thats all i could get I would give up
                                              Maureen wasnt happy with even a mere 5 thou DOC
                                              I did check the bolt and could use a file on it so not fully hardened
                                              A puzzle?
                                              Brian
                                              #565784
                                              Tony Pratt 1
                                                @tonypratt1
                                                Don't know who Maureen is but I suggest you check all the usual subjects, bearings, gibs, tool on centre height, etc etc.
                                                Tony
                                                #565789
                                                  Posted by brian jones 11 on 06/10/2021 09:52:44:
                                                  A puzzle?
                                                  Brian
                                                  A puzzle? Yeah, but no, but yeah.
                                                  Carbine is harder and more heat resistant than HSS, and it's at its best used far more brutally. The bluntness improves edge strength but also suits the rate at which carbide works best. It's counter-intuitive compared with HSS in that improving finish with carbide usually requires higher speed, feed-rate and greater depth-of-cut. HSS tends to improve finish by taking lighter slower cuts.
                                                  Problem with Miss Maureen Myford is she's too slow, weak, and bendy to get the best out of carbide, partly because her electric motor is called Weedy Walter.
                                                  Carbide produces good results on slower machines but it's a tad harder to get good finish with it: experiment.
                                                  The bolt not being fully hardened is a misunderstanding too. 8.8 bolts are tough rather than hard so they can be cut with a hacksaw or filed. However, there's no reason why a steel bolt should machine well. Ordinary mild-steel is a bit soft and smeary, Boron Steels are tough and smeary – an unfriendly material. Pot luck,
                                                    FWIW, from time to time, I turn 8.8 grade fasteners quite happily with HSS tools.
                                                    They need to be sharp and on centre height, with a fine feed.
                                                    Carbide tips are not as sharp as a properly ground HSS. In this way, they generate the heat at the point of contact to soften the material.
                                                    If you must use carbide tips, increasing the speed, so that you are running at about 3-400 fpm may help.
                                                    May be difficult to run fast enough if you are attacking a M8 bolt!
                                                    Edited By Howard Lewis on 06/10/2021 11:46:33
                                                    #565798
                                                      So which holder/insert were you using? yesterday you mentioned triangular inserts yet today you post a link to a set with no triangular inserts. Say which it is and I'll point you in the right direction.
                                                      The bolts are not hardened they are just made from steel that has a higher tensile strength that is not so easy to cut. If you want to use the bolt as a hob then it will need case hardening but then that's only surface deep and not so good for cutting tools better for wear resistance. better to get a bit of silversteel and make a hob from that that can then be through hardened
                                                      Edited By JasonB on 06/10/2021 12:54:48
