Ball screws
Ball screws
  • #566670
    Mark B
      @markb43031
      I'm planning on making my fist steps to converting a small machine to CNC and wanted some guidance on purchasing ball screws.
      Eliminating backlash is a of particular importance to me as I'm planning on making small clock parts. I'm not sure that my budget will stretch to ground ball screws, so the cheaper rolled ones will be my starting point.
      Lots available on ebay such as these and I wondered if anyone had any opinions on these? The kit includes the mounts which would be a good starting point potentially.
      I've chosen 16mm screws here, but for a small machine (like an SX2 Mini mill for example), would 12mm be adequate?
      Edited By JasonB on 13/10/2021 15:41:23
      #15369
      Mark B
        @markb43031
        #566681
        HOWARDT
          @howardt
          With ball screws you have to take both the nut and the screw design into consideration. Obviously the best would be a ground screw with a double nut, the screw can have the greatest pitch/travel accuracy and the nut balls are selected to give the best fit with the double nudt reducing backlash to a minimum.
          In machine design I used to use ground ball screws, but eventually these were replace by rolled screws and software position compensation. But this was all with proper servos and dedicated software.
          No doubt there is someone here that can answer your question from experience of what you want to do. Price will be the final answer, but think about what you are trying to achieve positional tolerance wise and can you measure that. I am sure like the rest of us you don't have a temperature controlled CMM.
          On a Z axis you will benefit from some sort of counterbalance, so you may well get away with a smaller screw size.. A hydraulic strut system would work, the final machines I designed had hydraulic cylinder systems.
          #566682
          Martin Kyte
            @martinkyte99762
            As clock parts were sawn and then filed to the line rolled ball screws will do fine. My mate Chris converted an X1 to CNC without replacing the leadscrews and it worked fine crossing out wheels and hogging out clock plates. Everything was then finished by filing which just amounted to nicking out the corners and removing the machining marks. Save your money for a high speed spindle although the cheaper way round is using a hand engraving spindle with a flexi drive and mounted inside the spindle of your chosen machine. Router cutters (1mm dia) are the cutters of choice for profiling. Wheel teeth and pinions are generally cut in the normal way.
            regards Martin
            #566683
            DC31k
              @dc31k
              If you are converting a machine, then asking about ball screw diameter is rather putting the cart before the horse.
              Decide on the machine and make some drawings of the space available for the nut and screw. That will then guide you in the diameter. Ball nuts for a given screw diameter are somewhat bigger in all directions than standard nuts.
              #566698
              John Haine
                @johnhaine32865
                16mm overkill and will take up a lot of space.
                #566703
                Mark B
                  @markb43031
                  Probably worth me saying a little more about what I'm doing. I'm basically trying to replicate a rose engine for decorative dial engraving.
                  This is the machine so far:
                  I'm going to attach 2 stepper motors, one for rotating the dividing head (in one direction only so backlash is not an issue), and another stepper for the left to right movement of the table which the dividing head sits on.
                  The idea is that you mount a dial on the dividing head which rotates as you apply an engraving tool to the surface. At the same time you move the head in a sine-wave type of pattern so add an interesting geometric shape to the dial. The sine-wave pattern could be quite small with an amplitude going down to 1 or 2mm potentially.
                  I've got the stepper motor for rotating the dividing head sorted although this isn't shown on the photograph.
                  The ball screw application is for the left to right movement of the table which the diving head sits on. This is the bit which makes the sine-wave or any other pattern I choose to make. The prototype I've made so far uses an acme thread, but the backlash is totally unacceptable for this application.
                  #566705
                  Mark B
                    @markb43031
                    My original post had a link to the ball screw kit from eBay, but this was removed… Is this not allowed in the forum?
                    #566706
                      See last item of Code of Conduct
                      #566710
                      Mark B
                        @markb43031
                        Posted by JasonB on 13/10/2021 20:56:52:
                        Understood; I'll avoid links to eBay items. Thanks Mark
                        #566720
                        Mike Poole
                          @mikepoole82104
                          Although ball screws are a good solution for a low backlash precision screw there are other solutions. Nuts can be adjusted to take out backlash which can be as crude as a sawcut in the nut and a bolt to pinch it up to remove the backlash. This will wear and and as the screw will wear as well then tight spots will emerge. Plastic nuts formed on the screw also work but again don’t last forever.
                          #566722
                          Anonymous
                            Be aware that, depending on pitch, ballscrews may be back-drivable if that affects you design.
                            #566729
                            Martin Connelly
                              @martinconnelly55370
                              Peter, he is going to put stepper motors on the ball screws so they will act as a brake against back driving.
                              Martin C
                              #566734
                              Emgee
                                @emgee
                                Posted by Martin Connelly on 14/10/2021 08:07:28:
                                Martin C
                                Only when powered up, the Z axis will need some kind of brake to prevent the head dropping with power removed.
                                Emgee
                                #566744
                                Mark B
                                  @markb43031
                                  I think I'm going to try the ball screw option which will be a SFU1204. In terms of mounting these, is there any preference to thrust bearings?
                                  #566773
                                  Martin Connelly
                                    Emgee, no mention of putting ball screws or steppers on the head, only two, one for rotating the dividing head and one for the x axis.
                                    Martin C
