x3 mill spares
x3 mill spares
Home › Forums › The Tea Room › x3 mill spares
  • #382600
    andy mulholland
      @andymulholland30577
      hi, I have a old x3 mill bought from arc eurotrade a good while ago..ive been out of the hobby for a while but starting to renew my interest and have found that the carbon brushes on the motor most probably need renewing.. I've phoned arceurotrade but apparently the older brushes are no longer available .. does anybody know differently or have any suggestions on the best way to proceed.. I was wondering if its possible to make up new bushes …any advice much appreciated..thanks….Andy
      #35329
      andy mulholland
        motor brushes
        #382615
          Measure them and see if you can find the size on the net, they can always be trimmed down
          #382618
          HOWARDT
            @howardt
            Thought I remembered a site during a recent search. Try this.**LINK**
            #382621
            andy mulholland
              thanks Jason , that's what ill do if I can't get them as supplied with the original motor.. they have brass caps attached to the brushes which locate in the brush holders.. it would have been easier if I could have sourced the specific item…thanks again
              #382622
              andy mulholland
                Posted by HOWARDT on 27/11/2018 18:47:56:
                many thanks , ill check out the link..
                #382624
                not done it yet
                  @notdoneityet
                  Anything bigger that will fit by cutting/filing them down will do – as long as you know whether the brushes are for an AC or DC motor.
                  #382642
                  John Rudd
                    @johnrudd16576
                    Having read the above comments, its not just about the physical size and composition…..there is the spring pressure to consider…where springs are fitted
                    So not all brushes are the same
                    Edited By John Rudd on 27/11/2018 21:31:25
                    #382643
                    Mike Poole
                      @mikepoole82104
                      There is quite a lot of knowhow that goes into the optimum brush material and spring pressure **LINK** . Try to get brushes from a motor that is of the same sort of size and application, it is going to be better to have brushes that are the right size even if the material is not ideal as worn brushes can start arcing and the destruction of the commutator quickly follows.
                      #382983
                      andy mulholland
                        thanks for all the comments, ive sourced what I think will do from the link provided by Howardt in one of the above posts…. i'll see what they are like and get back on the result..
                        Andy
                        #431288
                        ega
                          @ega
                          An additional supplier link:
                          solenttools.co.uk
                          They recently supplied a pair of brushes for my old Wolf Grinderette angle grinder.
                          This machine is over forty years old and I was impressed to find that they were able to supply against the type number of the machine. They also undertake to make brushes.
                          #431379
                          old mart
                            @oldmart
                            I notice that Arc mention the size of the old style brushes: 12 X 6 X 18 long.
