will brass work
will brass work
Home › Forums › Beginners questions › will brass work
  • #134996
    michael burton 1
      @michaelburton1
      hi will brass work as a slide valve material just i have a big block of brass that i can use the cylinder is cast iron so will brass work at the mo i cant afford to get any differant material so would rather use what i have??????
      also were would engineering plastics come in to use could you use somthing like acytel or delrin…………… this is just a courious question
      the model is only going have minimal use
      atb mike
      #6949
      michael burton 1
        @michaelburton1
        #135001
          For light use Brass will be OK though a bronze would be better. You could always silver solder a thin piece of bronze onto a brass block, if you cut a hole in teh bronze first then that will form the cavity in the valve.
          J
          #135205
          nigel jones 5
            @nigeljones5
            hi..if your not planning on powering the national grid with it brass will be just fine, in my experience avoid plastics, they do bad things when they get hot!!
            #135229
            Ian S C
              @iansc
              With a cast iron cylinder, steel could be used, but cast iron is better. Stuart Turner use bronze on engines like the S 9, and I presume their other engines too. Ian S C
              #135268
              nigel jones 5
                @nigeljones5
                Ian…totally agree that brass isnt perfect but it will last plenty long enough as a d-valve
                #135318
                Ian S C
                  @iansc
                  fizzy, true. I tend to over engineer thing, even when it not needed. Ian S C
