Where to buy small circular glass disks.
Home › Forums › General Questions › Where to buy small circular glass disks.
  • #23892
    David Cambridge
      @davidcambridge45658
      #190247
      David Cambridge
        I’d like to make a small fuel tank for my model engine – it will be very small and I’ll probably use 1 or 2 inches of copper pipe with a sight glass at one end. The trouble is, I’ve no idea where I can get a circular piece of glass just 2 or 3 cm in diameter. Does anybody have any ideas ?
        David
        #190248
        Ian Parkin
          @ianparkin39383
          any glass merchant will cut you 1 or 2
          #190249
          OldMetaller
            @oldmetaller
            David, I use watch glasses for glazing the cab windows on my 16mm scale locos, have a look at this website:
            http://www.agthomas.co.uk/watch_glasses.htm
            I use these people and they are good to deal with.
            John.
            #190250
            Ian Parkin
              @ianparkin39383
              I have some 22mm dia ready cut but only 0.17mm thick if they any use to you?
              #190312
              David Cambridge
                Marvellous – thanks all. The key was knowing to use the search term ‘Watch glass’.
                A special thanks to Ian – but unfortunately 0.17mm is a bit too thin, but no the less thank you.
                David
