What did you do today (2015)
Home › Forums › The Tea Room › What did you do today (2015)
Viewing 25 posts - 1,401 through 1,425 (of 3,154 total)
  • #192191
    ANDY CAWLEY
      @andycawley24921
      Yesterday actually. Made bushes for friction shock absorbers. Lignum vitae is particularly satisfying to turn giving a lovely silky finish. It's almost a shame to hid them at the end of a shock absorber😊Bush.jpg
      #192195
      Jerry Wray
        @jerrywray14030
        Posted by Bazyle on 31/05/2015 17:21:38:
        I machined off the cast iron blade guides for my new to me Startrite bandsaw (wood) to a new surface. These old machies were often in schools and now let loose for hobyists but well worn. For us machining the guides is trivial but quite daunting or expensive for a woodworker so if you know anyone with one do them a favour and do it for them.
        The back guide is supposed to be a rod with a carbide button but mine are mild steel with many grooves worn in seemingly original as it is the oldest model. Looked at the price of 10mm carbide rod and decided to give HSS a go and see how it wears.
        I may make roller guides someday as per modern practice but actually the CI guides allow blade support to within a few mm of the job for better accuracy.
        Next job is to make a mitre fence. Have you seen the price! There's simple ally casting and extrusion versions at over £100.
        When I was involved in boat building the blade quides on the bandsaws, Wadkin, Startrite, Record etc. were all lignum vitae. I still have a small stash ready for when I next need something as hard bur self lubricating.
        Jerry
        #192215
        KWIL
          @kwil
          Cromwell Tools. Right hand side of Home page "e–brochures" follow to there and you can find Savers– June news letter 103.
          #192228
            Posted by KWIL on 03/06/2015 10:19:44:
            Thanks for the link KWIL star
            I will have to check it on the computer, later.
            … Somewhat infuriatingly, if I try it on the iPad, it instructs me to download Adobe Flash Player [which is, of course, impossible under iOS]
            … I wonder why people can't just put this stuff up as a pdf or a web page.
            Edited By Michael Gilligan on 03/06/2015 11:54:35
            #192232
            Ian P
              @ianp
              Posted by Michael Gilligan on 03/06/2015 11:52:48:
              Absolutely right Michael!
              Mind you whether its Cromwell or Apple that should be blamed here is debatable.
              I find the Cromwell 'interactive' e brochure unusable on my PC. They show whole brochure page in a rectangle on a waste of space blank background. Zooming and panning is possible but its not practical for 30 or so pages.
              Do these people never ask their customers for an opinion!!!
              Ian P
              #192285
              Oompa Lumpa
                @oompalumpa34302
                Last night I made a windy, windy handle for the spindle to make single point close threading that much easier, come on, we have all done it, used the chuck key to rotate the chuck (nightmare when the chuck loosens!). Ended up being made all from stainless, I didn't plan it that way but the offcuts I had in the right size were all stainless, even the threaded bar. Handle was from a C3 though.
                so then this morning I rewarded myself with a trip to the range, drilling the 12mm plate on the right was pretty straightforward but the 15mm plate on the left is proving obstinate. Need to give 'em a bit more vim methinks and try again
                graham.
                (for those that would like to know – this is a .270 round with a 130 grain bullet on top of 43 grains of Hodgdon 4895)
                #192288
                Boiler Bri
                  @boilerbri
                  Decided that I have to stop trying to make batches of axles without the aid of stops on my lathe cross slide and compound slide. + here – there it all adds up and I really want them all the same.
                  Has anyone made an adjustable stop for the cross slide on a 5" boxford?
                  #192291
                  Bazyle
                    @bazyle
                    Brian, use the standard Boxford screwcutting stop but with a screw that has a very clean and positive shoulder set to stop at dead centre. Then make distance pieces to drop in between the screw and the bridge piece. (this may seem meaningless to some but shoud be clear to a Boxford user)
                    #192292
                      That's what happens when two computer companies who try to lock users into ;'their' system collide head on.
                      Bazyle
                        @bazyle
                        Overtook Dinmore Manor on the M25 about J18 at 7pm this evening. A friend saw some other loco on the road about there yesterday but I was some 10 mins later so missed that one.
                        #192304
                        Nick_G
                          @nick_g
                          Started to set up a tropical fish tank.
                          Nick
                          #192305
                            Posted by Neil Wyatt on 03/06/2015 21:46:54:
                            Agreed … and it's such a pity, because once-upon-a-time Apple and Adobe were very close. PostScript, PageMaker and PhotoShop spring to mind.
                            Edited By Michael Gilligan on 03/06/2015 22:53:11
                            #192329
                            OuBallie
                              @ouballie
                              Andy,
                              Where are those shocks used?
                              My '35 Austin Seven has friction versions as well.
                              Geoff – Progress being made on its Rejuvination at last.
                              #192332
                              mechman48
                                @mechman48
                                Nice to have the facility to a range & go bang, bang but what with the likes of Dunblane etc, we're rather severely restricted here in the UK… I have shot various weapons in the past & have shot clays on holiday… I was that 'weekend soldier' a long time back & would like to shoot again occasionally… but apart from joining the TA again… & at 67 … not!, still, envy comes to mind.
                                George.
                                #192335
                                Capstan Speaking
                                  @capstanspeaking95294
                                  Posted by mechman48 on 04/06/2015 10:33:26:
                                  George.
                                  It is very restrictive but there is stil plenty of fun to be had. Semi autos at 22RF and manual load even to 50 cal. Also muzzle loading pistols.
                                  There are also the "practical rifle" and "practical shotgun" disciplines.
                                  The item below is 100% legal in civil hands in the UK.
                                  #192347
                                    Doesn't seem the most practical way of spotting out loco frames.
                                    Rik Shaw
                                      @rikshaw
                                      With the lathe still with WARCO for repair attempt no. 2 I am restricted to non turning work.
                                      I have a pile of tool steel "dog ends" I have collected over the years and I felt today that the time was right to make a holder for them.
                                      I have made it double ended so it can be used for tiddly boring bits etc.
                                      It kept me busy for a few hours and stopped me pining for my absent friend.
                                      Rik
                                      #192385
                                      Stuart Bridger
                                        @stuartbridger82290
                                        Finally replaced the oil seals on the clutch shaft of my Chipmaster after getting fed up of most of the headstock oil. dripping on the garage floor. Learned quit a lot about how not fit an oil-seal, but got there in the end. A bit worrying was a nicely polished worn groove, where the inboard seal runs. Should have got a photo, but forgot. Hopefully it has done the job. Headstock now refilled and will be watching the level.
                                        #192389
                                        ANDY CAWLEY
                                          @andycawley24921
                                          Geoff, the shocks are off the back of my 1925 Frazer Nash.
                                          Edited By ANDY CAWLEY on 04/06/2015 19:07:59
                                          #192401
                                          Martin Cottrell
                                            @martincottrell21329
                                            Posted by ANDY CAWLEY on 04/06/2015 19:03:09:
                                            Smashing action shot Andy. I couldn't help noticing the back tyre looks a bit soft, is this a deliberate ploy to get more "off-road" grip or a puncture developing? I also noticed easy access to the foot pump strapped to the toolbox on the running board!
                                            Regards Martin.
                                            #192441
                                            ANDY CAWLEY
                                              @andycawley24921
                                              Martin, that's exactly right. The trick is to get the tyre pressure low enough to get maximum grip but high enough to stop the tyre rotating on the rim. We then have to pump the pressure up to go on the public road to drive to the next section.
                                              #192442
                                              Bob Brown 1
                                                @bobbrown1
                                                Isn't there a minimum pressure in the regulations? something like 12psi.
                                                Bob
                                                #192444
                                                NJH
                                                  @njh
                                                  Not by any chance the Exeter Trial I suppose Andy? It looks rather familiar ( although maybe not wet enough for that location!)
                                                  Norman
                                                  #192447
                                                  Oompa Lumpa
                                                    @oompalumpa34302
                                                    Posted by Neil Wyatt on 04/06/2015 12:37:34:
                                                    And a broken drill every time
                                                    Fun though.
                                                    graham.
                                                    #192552
                                                    Oompa Lumpa
                                                      @oompalumpa34302
                                                      Went to see one of my cousins girls, Ruby is five months pregnant and before she became pregnant, weighed in at a little over 1000 lbs. You really wouldn;t want her to stand on your toes!
                                                      Hand feeds and actually responds to her name, a huge beast. Very impressive and they are more pets than "just cattle" you can see from their condition (he has two, mother and daughter) that they are spoiled.
