Water Lifter Hose
Water Lifter Hose
Home Forums General Questions Water Lifter Hose
  • #26844
    tom hardy
      @tomhardy75463
      #429504
      tom hardy
        @tomhardy75463
        where can i buy steel reinforced lifter hose for a 1 1/2 traction engine
        tom hardy
        #429630
        Brian Sweeting 2
          @briansweeting2
          What size tube are you looking for and material type?
          There is a good range of 'plastic' reinforced tubing available.
          #429631
            Quite a few makers get a small rubber hose and then wind thing galvanized wire around it. You can leave as that or add a layer of self amalgamating tape. MJ Engineering do some suitable black rubber hose for just that job
            Heritage steam sell scale water lifter hose but only for the large scale engines
            #429636
            Clive Brown 1
              @clivebrown1
              For the 1 1/2" Allchin, W Hughes described wrapping tinned copper wire around 1/4" rubber tube. He suggested grey tube, which is not common, and fuse wire, 10 or 15 amp, I forget which, but it's 0.015" dia or 28 swg.
              His method was to wrap 3 lengths of wire side by side, then remove 2, to give the spacing.
              #429637
              Oldiron
                @oldiron
                Nip over to your nearest hydraulics & hose supplier or agricultural outlet. Depending where you are you could try these people. They will always help the small user. Hose supplier     regards
                Sorry just noticed you are in WA from your earlier posts.  The info should be of help to yourself and others though I hope
                Edited By Oldiron on 19/09/2019 15:22:18
                Edited By Oldiron on 19/09/2019 15:25:27
                #429638
                Trevor Drabble 1
                  @trevordrabble1
                  As per Jason's suggestion , Blackgates also sell a selection of suitable hose in different diameters.
                  Trevor.
                  #429833
                  tom hardy
                    @tomhardy75463
                    thank you people for the info well done
                    tom
                    #429920
                      I came across a suggestion of winding a loose spring with hard stainless steel wire, then inserting it into a tube of heat-shrink tubing. I imagine it isn't very flexible, but not sure how much you need it to bend.
                      Nick Clarke 3
                        @nickclarke3
                        Does it need to be steel reinforced or to have the appearance of steel reinforced?
                        In an article about making vacuum brake pipes W.A (Bill) Carter described how to wrap wire around a pipe and run an electric current through it to burn the appearance of the corrugations into the pipe.
                        If you need it I will dig out the reference to the issue.
                        Nick
