Warco super major
Warco super major
Home Forums Beginners questions Warco super major
  • #223058
    David Channon
      @davidchannon41345
      Hi
      I'm thinking of buying a super major mill from Warco, the price is right and I think for the money a good buy the only problem I have is the longitude travel of the table its states 550mm and is 550mm? the table is the same as the GH mill but that states 585mm. I need 610mm and was wondering if anyone had done this type of modification? from looking at the mill there are two cast webs that the handle case hit? I was thinking that these could be removed to give me more travel?? anyone see a problem with this??
      Edited By David Channon on 29/01/2016 16:39:35
      Edited By David Channon on 29/01/2016 16:43:12
      #7981
      David Channon
        @davidchannon41345
        #223066
        Michael Topping
          @michaeltopping17870
          I have a Super Major. There is only a boss on the left hand side which is the mounting for the power traverse. It could be spaced out by 60mm yo get the travel you need but I think you would need a longer lead screw.
          The only issue I have had with this mill is the noise of the motor, so noisy that I finally replaced it with a motor/inverter package from Transwave and the difference is huge. Now a pleasure to use.
          Michael
          #223962
          Jon
            @jon
            Bit late but you wont get it with a power feed attached in any shape.
            I have the Chester supplied Zay in 2004 even with an extended lead screw and proper power feed on right you will only achieve 547.58mm. Originally got think it was 585mm.
            Could increase travel highly not recommended as is bed deflects visably150mm either side of central due to bed sagging because thickness of top slide is thin. I would also argue the foot print top slides mounted off is on the narrow side for bed length.
            Only option bigger mill £5k+ or Bridgeport.
            Issues are parts its Chinese could be waiting many many months and stung big time. ie transfer box (the bit in between motor and vertical slides for powered head £244, whole mill £930.
            Lead screws could adapt decent ones, they wont last my vertical has over two revs backlash and X around 1 1/2 revs surprised it still works.
            Motor noise fine its not over powering but lacks speed above 1250rpm. US modded ones have decent bearings fitted to allow faster speeds at a price!
            Worst problem is the quill after years of service the bores oval. No load and no lock on centred then put quill lock on throws to the back 0.46mm even with a bodge job drilling around quill casting putting pins in.
            Diy should last about 10 years anything more look for British or another quality item. Semi pro ok for 3 years as long as no accuracy needed.
            #223965
            Jon
              @jon
              Just to add that 547m travel both ends, bed and end castings goes way past the footprint around 4" in each side even the handles near level.
              Most are MT3 as is mine no problems but look around might pick up one with R8.
