using Clarkson for drills
Home › Forums › Workshop Tools and Tooling › using Clarkson for drills
  • #197250
    mick70
      @mick70
      Clarkson sharpener I got hasn't got holders with it.
      Will the 5c c type holder arc sell be ok to use for holding drill bits to sharpen?
      Fair way of using it yet but thinking ahead.
      #17771
      mick70
        @mick70
        #197251
        Involute Curve
          @involutecurve
          I use ER32 with a holder I made I then sharpen using 4 facet mathod.
          Shaun
          #197253
          John Haine
            @johnhaine32865
            5C would be fine with 4 facet method for the exact size drills, but for other sizes not. So using an ER style collet system would give you a greater range. Depending on what size 5c collets you have one approach would be to use an ER collet parallel mandrel in a 5c collet, putting the drills in the appropriate size ER collet. See for example
            http://www.arceurotrade.co.uk/Catalogue/Collets/ER-Milling-Collet-Chucks-Straight-Shank
            Edit for clickable link.
            Edited By John Stevenson on 19/07/2015 12:58:45
            #197256
            John Stevenson 1
              @johnstevenson1
              Or a 5C to ER32 adaptor.
              Third up from bottom.
              #197274
              John Haine
                @johnhaine32865
                Indeed, just the ticket.
                #197301
                mick70
                  @mick70
                  looks like Ketan is getting all of next months overtime money.
