Stationary Engine bases M E article.
Home › Forums › The Tea Room › Stationary Engine bases M E article.
  • #825745
    the artfull-codger
      @theartfull-codger
      Hi, can anyone remember which date in Model engineer the article on making bases for stationary  models was printed, a really good article, imitation bricks etc, think it was by Neil or one of the regular contributors, [to save me going through my copies.] thanks .
      #825751
        the artfull-codger
          @theartfull-codger
          Thank you for the reply Jason, excellent work from you [AS ALWAYS!] usefull info there
          I always enjoy your builds., the actual article was by one of the mods/contributors as I remember. showing various different designs for bases, if no luck I’ll be going in the loft for half a day thumbing through back issues.
          #825882
          Clive Foster
            @clivefoster55965
            Pretty sure I know the article you mean but not a clue where to find it. Worth trying the indexes but I have to admit my search-function isn’t that good with the ME / MEW ones. User problem not index problem.
            #825884
            bernard towers
              @bernardtowers37738
              Try imes.org.uk
              #825891
                Neil probably did it on his Nordene engine and if a separate article would have used some of that as an example.
                Quick look and it is 4642 3rd July 2020. Realistic bases for models by Neil
                #826114
                the artfull-codger
                  @theartfull-codger
                  Hello Jason, I must thank you for taking the time to send me the M E date/number of the M E with the details by Neil, Yes this is the one I wanted you’ve saved me a lot of searching. Thanks once again. Also Thanks to Bernard Towers & Clive foster.
                  Regards.
                  Graham.
