When I purchased my Centec 2b, it was fitted with what looked like a large single phase motor. I fitted a 3 phase motor and VFD and put the single phase motor to one side.
I have been sorting and testing all my electric motors over the past month and this particular motor puzzled me, it has two separate windings and nothing else, no centifugal switch or any capacitors although it has a large (empty) box on top of the motor. One coil was connected to the mains feed when it was taken out of the mill.
Subsequent research reveals that it is a 3HP single phase motor designed for air compressor use. There is no manufacturers plate and the clue was given by some lettering on the aluminium casting.
Seems a waste of a motor and goodness knows how the last owner thought it would run in the mill! I am not bothered about the starters used in air compressors. I was thinking of wiring it up as a capacitor start motor, with a suitable starting capacitor. Not sure which of the windings would be the start winding, but should be able to figure this out. There is room for a centrifugal switch with some modification.
My concern is that these air compressor motors may have some unusual feature that might prevent such a simple minded approach from working. Not being familiar with them, makes me a little cagey. Googling for some while left me non the wiser.
Andrew.
Edited By Andrew Tinsley on 03/01/2021 19:23:58
