Stand for WM16B Milling Machine
Home Forums Workshop Tools and Tooling Stand for WM16B Milling Machine
  • #572898
    Bo’sun
      @bosun58570
      Good morning All,
      I need to build a stand/bench for my Warco WM16B milling machine. Any thoughts about a good ergonomic height for the milling machine table?
      The Warco stand for said machine is 813mm tall. Does that sound about right? It would put the machine table height at about 980mm.
      I did consider the Warco stand (& tray), but unless it's bolted to the floor, it looks a little unstable. I intend to build a largish bench for my mill, so stability shouldn't be an issue.
      #20508
      Bo’sun
        @bosun58570
        What height?
        #572899
        Journeyman
          @journeyman
          Rough guide is to get the Y-axis handwheel at about elbow height. It does depend also on how tall you are. Factor to bear in mind with the WM16B is that the Z-axis handwheel is at the top of the column and will be at the rear of whatever stand you build. Unless there is side access the Z-axis handwheel can take some stretching to reach.
          Edit:Typo
          Edited By Journeyman on 25/11/2021 11:28:09
          #572900
          Dave Halford
            @davehalford22513
            A good ergonomic height is the one that suits the user, so work it out from the height your hands end up at when you pretend to twiddle the lead screws.
            Does 980mm make you bend your neck too much?
            #572903
            Bo’sun
              @bosun58570
              Thank you John & Dave, some food for thought. I'll go and have a twiddle in the privacy of my workshop.
              #572905
              Dalboy
                @dalboy
                I brought the warco stand when I brought my mill but to me it seems a little too low but I have found if I sit on a stool it is the right height which for me can be idea as I have arthritis in my spine. But for simple jobs where I stand as I said above it is too low, It does say it is 720mm tall
                #572914
                Bo’sun
                  @bosun58570
                  Thank you Derek,
                  It looks like you have the WM18 mill. Not that it makes any difference, because I suspect all of the tables will end up at the same height.
                  #572916
                  Stuart Smith 5
                    @stuartsmith5
                    I have a WM16 which I bought secondhand and it came with a Warco stand. The Warco measurement for the stand is correct at 813mm, though I have not used it. I extended my existing bench which is 930mm high and mounted the mill on that. Never having used a mill before, I don’t know if this is considered too high but I find it ok – I am about 5’8”.
                    If you go for the Warco stand, it will need to be bolted down.
                    Stuart
                    Edited By Stuart Smith 5 on 25/11/2021 13:23:54
                    #572918
                    Dave Smith 14
                      @davesmith14
                      I am 6ft and have Warco stand. Height is fine for me. Without a stand I would set it at kitchen worktop height.
                      #572920
                      Journeyman
                        @journeyman
                        Yes the stands are at different heights for the various machines in the range Viz:
                        • WM14 – 865mm
                        • WM16 – 813mm
                        • WM18 – 720mm
                        Smaller machines have higher stands. My own wooden bench for my WM14 mill is 889 (35" ) high which suits me at 6' 1" tall.
                        Edit:Remove emoji
                        Edited By Journeyman on 25/11/2021 13:47:46
