Spring Materials
Spring Materials
Home › Forums › Beginners questions › Spring Materials
  • #96451
    Deltic007
      @deltic007
      Hi all,
      I need to get hold of some Tufnol strip to make up a leaf spring assembly,Question is where from?
      Nobody seems to sell 7/16 x .070" or even wider to cut down. Reeves do sell some but nothing that fits the bill.
      Is there an alternative i could try?
      #6295
      Deltic007
        @deltic007
        #96452
        Andyf
          @andyf
          Maybe SRBP printed circuit board, though it's usually 1.6mm thick which is 0.063", and a couple of thou less if you strip off the copper.
          Or paxolin sheet, like this 0.0625" stuff LINK
          Edit: I see that Tufnol themselves do a 2mm (0.079" )thickness ANOTHER LINK . Don't know what the minimum quantity is, though, and I think there's a tolerance of plus or minus 5%..
          Andy
          Edited By Andyf on 16/08/2012 11:00:33
          Edited By Andyf on 16/08/2012 11:01:57
          #96453
          David Littlewood
            @davidlittlewood51847
            These people: **LINK** sell Tufnol sheet, though the thicknesses are 1, 2, 3 etc mm, so you might have to do a bit of re-calculation.
            David
            #96463
            Steambuff
              @steambuff
              M-Machines sell Tufnol Strip & Sheet in various sizes. (They should cut it down to the size you want if you ask)
              Dave (No connection, just a happy customer)
