Spotting drill or centre drill
Home › Forums › General Questions › Spotting drill or centre drill
  • #28580
    Former Member
      @formermember12892
      #585016
      Former Member
        @formermember12892
        #585023
        Emgee
          @emgee
          I would usually drill through both clamped plates with the tapping drill, then use a clearance drill on 1 plate.
          Emgee
          #585024
          Thor 🇳🇴
            @thor
            I too drill through both plates with the tapping drill, then clearance drill. For starting the tapping drill I first use a spotting drill (using the dials on the milling table handwheels to place the spotting drill), then the tapping drill.
            Thor
            #585027
            Former Member
              @formermember12892
              #585032
              Emgee
                @emgee
                I would spot it with a drill the same size as the existing hole, only needs a light touch to give a point for the spot or centre drill to use.
                Emgee
                #585033
                magpie
                  @magpie
                  Spotting drill.
                  #585043
                  Hopper
                    @hopper
                    I use the same size drill as the existing hole, so its a nice tight fit when I drill the start of the hole in the other plate, gets the new hole nice and central. Just sink the drill in to the edges of the tip, then change to the tapping size drill or pilot drill if you are going to use one. I don't bother with a centre drill or spotting drill in this instance as the larger drill has already provided the starting divot in the bottom plate.
                    #585052
                    John Baron
                      @johnbaron31275
                      Posted by Hopper on 11/02/2022 11:31:19:
                      Exactly what I do ! Saves time and you end up with an accurately drilled hole.
                      #585060
                      Dalboy
                        @dalboy
                        If you by chance have a set of transfer punches use them
                        #585061
                          I'd do them separately using the DRO to set out the holes. Spot and clearance size in one plate. Spot and tapping size in the other and while it's on the mill use that to also guide the tap perfectly perpendicular
                          Missed the edit, if I did not know the hole ctrs then use a spotting drill if I have one that fits existing hole if not use a drill bit of the same size to transfer onto the undrilled material.
                          Edited By JasonB on 11/02/2022 12:58:09
                          #585215
                          larry phelan 1
                            @larryphelan1
                            Hi Br
                            I thought you made it perfectly clear.
                            Must be missing something ?surprise
