Small universal/ball joint
Home › Forums › General Questions › Small universal/ball joint
  • #25889
    Peter Fishwick 2
      @peterfishwick2
      #346711
      Peter Fishwick 2
        @peterfishwick2
        I'm looking for a small ball joint that I can attach to a flat fixed surface, with the rod attached to the ball so that the rod can move in all directions. The end result is the sort of thing you would have with the aerial of a old style transistor radio.
        I can find ball joints for attaching to the end of rods to act as linkages, but none which can be attached to a flat surface.
        Any suggestions?
        #346712
        vintagengineer
          @vintagengineer
          #346722
          not done it yet
            @notdoneityet
            Camera? Dash cam? Sat nav? All, or most, use ball joints.
            #346725
            jimmy b
              @jimmyb
              Is this the sort of thing you are thinking of?
              Jim
              #346727
              Mick B1
                @mickb1
                Posted by jimmy b on 19/03/2018 15:08:30:
                Jim
                Thank you for that link. I'd wondered what'd happened to Woodside since the '80s when I last used 'em!
                #346739
                Robert Dodds
                  @robertdodds43397
                  Peter,
                  Have a look at this Amazon product with a swivel ball joint. It may be the wrong scale for your application but the principle of a slot down the side of the ball cup to allow the "vice" (or your rod) to lean over should give you the flexibility you seek.
                  40231901 Aluminum Small Mini Table Clamp Hobby Jewlery Work Swivel 360 Vice
                  I got one out of Aldi some time back and it's useful.
                  Bob D
                  #346743
                  SteveW
                    @stevew54046
                    May be worth looking into the model boat world. Many varieties for a limited angular displacement. Some very simple.
                    #346806
                    Perko7
                      @perko7
                      Some camera tripods, the collapsible/compact ones, have a ball joint for the camera mounting plate. Also some go-pro and dashcam mounts.
