Small Blower Valves
Small Blower Valves
Home › Forums › Beginners questions › Small Blower Valves
  • #53945
    Capt Dash
      @captdash
      I”m building Minnie using Len Mason”s excellent book BUT – on page 147 he says “A way of making really small neat looking valves was described in Model Engineer of 18th August 1967… etc”.  End of story!!
      I do not have a copy of the mag nor can find a reprint on the web.  Has anyone got a pdf of the article or can tell me where to find one?
      Taupo NZ
      #5130
      Capt Dash
        @captdash
        Blower Valve Construction Minnie Traction Engine
        #53947
          I just made mine to the drawings and it works OK, think It may have taken two attempts as I got too much silversolder in it first time round
          Jason
          #53970
          John Olsen
            @johnolsen79199
            Hi Dave,
            Well, that issue should be in the box downstairs, and failing that the Auckland SME will have it. I will see if I can dig it out. As you will gather I am not too far away from you, globally speaking.
            John Olsen
              @johnolsen79199
              Ok, that didn’t take long to find. Do you want to provide me with an email address? Use at instead of @, not sure if it helps to fool the spam bots but it is worth a try.
              The valve in question has a body quarter of an inch diameter, shown with a flange one side and a union the other, but the same thing could be done with two unions I guess. It does conform to the modern idea that you can’t just screw the spindle right out. It looks reasonably fiddly to make, and the job depends on keeping the easiflo out from where it is not wanted….you might be able to improve things there by using the twink idea on bits you want to keep clear.
              regards
              Les Jones 1
                @lesjones1
                Hi Dave and John,
                                           Use the “My messages” system on this forum to pass your email address. That avoids any risk of spam.
                Les.
                #54228
                Capt Dash
                  @captdash
                  Thank you to all that responded.  I’ve corresponded with John via “My Messages” and look forward to his reply.
                  John Olsen
                    @johnolsen79199
                    The scan should be in your email inbox by now, unless the spam filter grabbed it on the way past.
                    regards
                    XueSong Zhou
                      @xuesongzhou39225
                      hello,
                      Questions about combustion engine?
                      If you need,please leave a message.And I am glad to help.
                      My name is XueSong Zhou,Chinese,now the General Manager of CQ Kang cummins diesel engine parts Ltd.
                      And,my little shop stores some CUMMINS PARTS!Our main products: Cummins overhaul accessories, assembly parts, filter, crankshaft, connecting rod, fuel injection, etc.( Involving models for NT855, KTA19, M11, L10, ISM11, QSM11, QSK19, KTA38, KTA50 etc. cars, ships, construction machinery, such as parts)
                      Here is my home page URL.
                      #54255
                      Ian S C
                        @iansc
                        Ho hum, or eastern gentleman is back, and he’s of topic again! perhaps he should tell us about his own model engineering exploits, I,m sure there must be model engineers in China. Ian S C
