Hi Steve,
You are correct – Silverflo 55 flux does not exist!
You have a flux that has been used in the past with silverflo 55.
It could be either a low temperature short life flux or a higher temp long life flux. Not knowing your brazing requirements, it is impossible to suggest the best alternative either EF flux or HT5.
Sorry Neil,
but both have a long shelf life made longer by the addition of a little detergent and water to make a yoghurt consistency paste. When this dries out (and it will) it can be reconstituted with a little more water.
No need to throw it away when it dries as hard as a brick!
Keith
