Russell in 5″ g.
Russell in 5″ g.
Home › Forums › General Questions › Russell in 5″ g.
  • #118423
    Kris Lehane
      @krislehane86422
      It can be done. Honest guv! has anyone else tried it? I'm about to, care of a slight scale up from 3.5. Anyone else interested? Beware, the frames work out at 50" long, boiler is easy, compared with a pacific, but expensive, and scaling it up means 8" dia, perhaps a trip into duplex steel… A new & interesting build.
      #22615
      Kris Lehane
        @krislehane86422
        Start of perhaps a long thread…
        #118427
        Kris Lehane
          @krislehane86422
          Boiler is indeed 8 inches, give or take. A venture into castellated joints, and rollers. 4 mil thickness.
          #118432
          Jeff Dayman
            @jeffdayman43397
            Are you seriously thinking of building an 8" dia duplex stainless steel boiler 4 mm thick with a castellated joint? I would not recommend this combination in any circumstances, and I would consult a boiler inspector before buying any materials. No qualified weld inspector will approve a castellated joint in any mild or stainless steel boiler. 4mm thick is very light for a stainless steel boiler design 8" dia unless WP is very low. In mild steel a 4 mm thick 8" dia boiler design would not likely be approved due to insufficient corrosion allowance over time, with the light stock.
            Are you talking about the Welsh Highland Rwy 'Russell' narrow gauge locomotive?
            Is this your first locomotive?
            JD
            #118513
            loco man
              @locoman67579
              I would query that for an 8" outside diameter x 4mm thick boiler the working pressure would have to be 'very low' A quick check, assuming a working pressure of 120psi, gives a hoop stress in the barrel of only 1,31 tons per square inch (hoop stress = pressure x inside diameter / twice thickness).
              Even if a relatively low grade of stainless was to be used, say of an ultimate tensile of 28 tons per square inch, this would give a factor of safety of 21.4:1 based on ultimate.
              There are other factors to consider though, such as the widespread opposition in the UK to stainless steel boilers whereas on the continent boilers tig welded from 316L stainless seem to be commonly accepted – even preferred.
              #118524
              MICHAEL WILLIAMS
                @michaelwilliams41215
                If Jeff or myself wanted to design a pressure vessel 8 inches diameter in stainless steel then no doubt either of us could come up with a credible design .
                Its that word credible that will cause all the problems in a small stainles steel boiler designed by an amateur . Design , designer , manufacturing process and testing process all have to be credible to quite a high standard .
                Hoop stress is only one of many design considerations – any actual design has to take into account material suitability , joint stress , stress concentrations , fatigue life , corrosion , welding procedures , NDT , overall safety case and many other things .
                The advantages of copper boilers over any ferrous designs in smaller sizes are that the copper boilers are supported by a huge body of experience and are in any case much less sensitive to things like corrosion and fatigue and slight flaws in joints . A copper boiler which is reasonably well made and looks like any other established design of copper boiler is very likely to be safe by default .
                Please don't misinterpret any of what I have said above – Designing and making of a stainless steel boiler by an amateur is perfectly possible – but the person concerned will have to do a lot of learning first .
                Michael Williams .
                #119335
                Jeff Dayman
                  @jeffdayman43397
                  Almost a week gone by and no word from OP.
                  I hope there wasn't a build attempt and a resulting mishap….
                  JD
                  #119346
                  Jeff Dayman
                    @jeffdayman43397
                    JD
                    #119355
                    Jeff Dayman
                      @jeffdayman43397
                      JD
