Reducing Bush or Sleeve
Home › Forums › Workshop Tools and Tooling › Reducing Bush or Sleeve
  • #188919
    James A
      @jamesalford67616
      I have bought a pulley to set up my Flexispeed lathe, but need a plain bush to sleeve it down from a 38mm bore to 16mm for the shaft. Can anyone suggest where I could get such a thing? I have looked, but can find nothing this size. I did buy a taperlock sleeve, but misunderstoodwhat they were for and it does not work.
      Alternatively, for a price, would anyone be willing to turn one for me?
      Thank you.
      James.
      #17706
      James A
        @jamesalford67616
        #188920
        John Haine
          @johnhaine32865
          How long and how fix to shafts?
          #188925
          James A
            @jamesalford67616
            John,
            It needs to be an inch long and secured with a grub screw or even loctite. It is not keyed.
            James.
            #188930
            John Stevenson 1
              @johnstevenson1
              Double check that 38mm size.
              As 38.1 is 1.5" and 38 isn't a usual standard size.
              #188943
              James A
                @jamesalford67616
                John,
                I have checked and you are correct: it is 1.5". I should have guessed that it would be imperial, really, as the diameter of the pulley is cast intoit in inches.
                James.
                #188945
                  And the shaft is likely to be 5/8" not 16mm.
                  #188946
                  James A
                    @jamesalford67616
                    Posted by JasonB on 07/05/2015 07:26:26:
                    Jason.
                     Yes – just double-checked and it is 5/8". I took it at face value that it was 16mm when I picked it up.
                    So: I now need a bush 1.5" OD, 5/8" ID and 1" long.
                    James.
                    Edited By James Alford on 07/05/2015 07:37:22
                    Edited By James Alford on 07/05/2015 07:37:44
                    #188950
                    old Al
                      @oldal
                      Very simple job if you had the pully in your hand. Just bring it round and I will do it over a cup of tea. I cant understand why nobody at the local model club has offered.
                      #189052
                      James A
                        @jamesalford67616
                        Old Al,
                        Thank you for the offer: I have had another similar offer and have taken that one up. The main reason why the local club has not offered to help is because I am not a member. To be honest, it hadnot even occured to me to join.
                        James.
