Recovery of oversized sheaves
Home Forums General Questions Recovery of oversized sheaves
  • #494821
    Tony Martyr
      @tonymartyr14488
      I have finally got round to stripping and rebuilding a model triple expansion engine that I built from Reeves casting some years ago. I am very impressed by some of the work (!?) except that all the excentric sheaves seem to be too loose – can't be wear from the few hours run so I must of not appreciated the clearances needed when I built the engine. The thought of machining a completely new set of 6 sheaves or excentrics fills me with dread so I wondered about 'remetaling' the sheave bores with silver solder and reboring. This is probably more difficult than making new excentrics but seems more interesting.
      Has anyone done such remedial work succesfully?
      Tony
      #27625
      Tony Martyr
        @tonymartyr14488
        #494826
        Brian H
          @brianh50089
          Hello Tony, what materials are the sheaves and straps made from? If the straps are one of the brasses then a coating of white metal bearing material should do the trick at a much lower heat than silver solder which may lead to distortion.
          #494877
          Tony Martyr
            @tonymartyr14488
            Hi Brian, Your reply has triggered a memory of my apprenticeship days and metalling of big gearbox bearings – this led me to the answer! I will mill a small amount of each of the halving joints, thus pinching the bore below size on the vertical axis and then machine out to the correct size, there is sufficient metal in the casting to allow this – I don't have to add metal!!
            cheers – Tony
            #494888
            Jim Nic
              @jimnic
              Surely what is proposed will indeed reduce the bore size in the vertical plane, but leave the opposing, horizontal plane the same dimension, ie still oversize. As I see it after machining the reduced vertical bore you will still have a sloppy side to side fit. Or am I missimg something?
              Jim
              #494890
                A lot will depend on how oversize the holes are, as soon as you start to take metal off the mating faces the cord will become less than the diameter which may just be enough. The smaller the sheave diameter the more the reduction for the same given amount removed from the mating faces.
                Edited By JasonB on 09/09/2020 14:56:48
                #494911
                Tony Martyr
                  @tonymartyr14488
                  Since the working loadlines in the top and bottom halves must be 50 odd degrees centred on the vertical centre-line I don't think the crescent shaped gap around the halving joint is going to be of concern, indeed it may aid lubrication. As Jason says it all depends on the amount the originals are oversized. I will do some careful measurement and report back.
                  Tony
