RECORD 03 Wood Plane Rear Handle Thread
Home Forums Help and Assistance! (Offered or Wanted) RECORD 03 Wood Plane Rear Handle Thread
Viewing 15 posts - 1 through 15 (of 15 total)
  • #615976
    Martin King 2
      @martinking2
      Hi All,
      I am in the process of sorting out a very nice RECORD 03 Smoothing Plane that has some issues, the main being a broken off rear tote securing screw.
      Naturally it has broken off right at the casting and there is also a broken off tap where someone else has had a go!
      I have the body casting set up in the mill at the correct angle and have drilled the old screw & tap out. Loctited in a nice snug fitting steel plug ready to re drill and tap.
      Does anyone have one that they could please check the correct thread for me? looks about 20tpi or so but I have no part to reference.
      Cheers, Martin
      #34090
      Martin King 2
        @martinking2
        #615977
        HOWARDT
          @howardt
          I had a selection of old planes with various screws missing, I think the basic thread may be 3/16 BSF. Amazon have selections of the required parts and I bought one of these. Some parts fitted some planes but not all, so there is a difference between Record and Stanley dependant on age. There is lots of information on the net which I read at the time so just have a search.
          #615981
          Brian Wood
            @brianwood45127
            Hello Martin,
            I've taken my Record #3 to pieces. The thread is odd at 0.210 inches across and very definitely 20 TPI, so make what you will of that!
            I might be inclined to tap it out at M6 and mark the plane accordingly.
            Best wishes Brian
            #615984
              7/32" x 20 see here
              #615985
              Brian Wood
                @brianwood45127
                Jason has once again found the information you needed and it confirms my findings today
                #616005
                Clive Brown 1
                  @clivebrown1
                  I'm amazed that a firm with roots in the Black Country in the 19th. century and later in Yorkshire, used American form unified theads in pre WW2 products.
                  #616008
                    Posted by Clive Brown 1 on 04/10/2022 19:24:07:
                    All the more surprising that they mixed Whitworth and Unified thread forms on the same tool.
                    … There must surely be an interesting story behind that.
                    ega
                      @ega
                      Posted by JasonB on 04/10/2022 16:17:36:
                      7/32" x 20 see here
                      Excellent find!
                      Where is the Stanley equivalent?
                      #616029
                        here is one of several if you care to look also gives an idea why Record used some American threads as they like others just copied the Stanley designs. Though do check if it's an American or English made Stanley and of what vintage as the newer UK ones have some metric threads.
                        The two pdfs in that link have a lot of infor too.
                        #616037
                          Those two PDFs make good reading
                          .. thanks Jason yes
                          Edited By Michael Gilligan on 05/10/2022 08:20:45
                          #616050
                          Martin King 2
                            @martinking2
                            Hi All,
                            Sent an email to Tracy Tools who replied overnight with their normal expedient service!
                            " Good Morning, thank you for enquiry, we can only help with the taps, we have in stock HSS £30.00 PER TAP, Dies would have to be made as a 1 off special, cost for 1 off would be in region of £200.00 possibly more if tooling charge was required"
                            Ouch! Guess I will use another thread!
                            Cheers, Martin
                            #616051
                              Could you not screwcut the male thread?
                              #616055
                              Martin King 2
                                @martinking2
                                Hi All,
                                Got this from Tracy Tools when I asked if they had enquiries for this size:
                                "Not really , last time we sold a tap was 2015"
                                Martin
                                #616067
                                ega
                                  @ega
                                  Posted by JasonB on 05/10/2022 07:06:28:
                                  Again, thanks; I have bookmarked these for future reference.
                                  I suppose that using the American threads gave some interchangeability for spares.
