Pulley wheels I think‽
Home Forums Beginners questions Pulley wheels I think‽
Viewing 25 posts - 1 through 25 (of 26 total)
  • #228371
    Izack Madd
      @izackmadd89335
      Hi,
      Hope you've all recovered since my last insane request. Because it the weekend my mind is working overtime and I'm struggling.
      I'm trying to find some pulley wheels to upgrade a 44mm diameter table saw. My problem is I can source drive shafts. I can source mounted bearings. But I need to transfer the power from one pulley to another via the drive shaft which means that the drive shaft need to be fixed to the pulley. I assume similar to the old mechano style pullies but be capable of turning at 5000 rpm without exploding. Now my terminology is always faulty and open to correction but I'm hopeful the reference to the old construction kit even if spelt wrong. Helps.
      I am also on the hunt for a flanged arbour for the same to hold a 10mm bore 58mm saw blade.
      For some reason it seems only the USA has these sorts of thing but as the postage is four time the cost of the part it's not a goer. Even if some one is willing to create these things I'm willing to pay a fair price. I just want to get them.
      Please can anyone help‽ ?
      Your friendly neighbourhood nutter.
      Izzy
      #8033
      Izack Madd
        @izackmadd89335
        #228382
        Sam Longley 1
          @samlongley1
          Are you describing plummer blocks & shaft
          If so then as a starter try http://www.arvis.co.uk/products.php?product=33
          then start googling around that
          I do recall seeing saw table sets years ago which had a shaft mounted on 2 plummer blocks & machined to take pulley one end & sawblade the other. Try J & M Belts or a bearing supplier & they may be able to source a suitable set
          #228386
            Posted by Sam Longley 1 on 05/03/2016 06:21:20:
            Izzy,
            Look for an old Picador catalogue … you should find plenty of inspiration along the lines that Sam suggests.
            John Hinkley
              @johnhinkley26699
              Unless I've very much misunderstood the original posting, I think izzy is going to have difficulty finding plummer blocks small enough to accommodate a saw blade of 58mm diameter. At 5000rpm, you are getting towards Dremel speeds! A picture of the set up with the original 44mm blade might help us to visualise what you are trying to achieve. I have in my mind a saw table for producing matchsticks, at that size!
                Good point, John
                I was only suggesting the old Picador products for 'inspiration'
                Also worth looking at this article about a miniature Spindle Moulder [thanks, Neil]; which is on the right sort of scale.
                Edited By Michael Gilligan on 05/03/2016 07:27:00
                #228397
                  Not sure Izzy needs help finding plummer blocks… he wants small pulley that will lock to the shaft and be OK for 5000 rpm.
                  I suggest looking for H-section poly-vee pulleys and belts.
                  http://www.bearingshopuk.co.uk/belts/poly-v-belts/
                  A suitable flange wouldn't be hard to turn from scratch.
                    Posted by Neil Wyatt on 05/03/2016 08:57:39:
                    Neil,
                    I can find the H-section poly-vee belts, but no suitable pulleys dont know
                      Second table down, belt pullies for 8mm shafts. I'd go with round belting as the pullies are going to need to be quite small dia particularly the one on the saw spindle if you are going to get any depth of cut.
                      HPC have the poly V pullies but they start at about 60mm dia
                      What bore is the existing 44mm blade? may just be able to use a bush to allow the new 10mm one to fit the existing flange
                      Edited By JasonB on 05/03/2016 10:21:38
                      #228417
                      Les Jones 1
                        @lesjones1
                        I think Meccano pullies would be safe at 5000 rpm. Search on ebay for "meccano pulley"
                        Les.
                        #228420
                          The minimum diameter for H-section poly v is 13mm and you can have any amount fo power transfer just by making it wider.
                          They can be very compact, if you can find someone who stocks or can order goodyear belts the smallest is 100H which gives you a centre distance of about 30mm with 13mm pulleys.
                            Posted by Neil Wyatt on 05/03/2016 10:51:46:
                            +1
                            … assuming that you can buy [afford], or make suitable pulleys.
                            KWIL
                              @kwil
                              Proxxon's FET table saw runs at 7000rpm and uses Optibelt toothed drive belt. Their saw bore is 10mm dia.
                              #228435
                                Posted by Michael Gilligan on 05/03/2016 10:55:56:
                                I suspect you have to make – they are little used by industry but turn up in copiers, printers and the like.
                                Very easy to make, but I'm not sure if Isaac has a lathe?
                                If not, time to get one
                                Izack Madd
                                  @izackmadd89335
                                  Hi,
                                  Sorry for the late replies I've been out all day with family. I've not read anything yet but I'm sure your advice is invaluable as always.
                                  Thanks in advance
                                  #228511
                                  Izack Madd
                                    @izackmadd89335
                                    Hi,
                                    I thank you all. And I think my main issue is either I don't know the right name for what I need or as with Sam and such is that they don't do this sort of thing nowadays.
                                    The original flange for the 44mm blade is bore/shaft. It. Was the extra width of the proxxon b,aides I was hopeful of using. Hence the wish for a 10mm shaft with flange.
                                    But I can get toothed pullies used for 3D printers that have a grub screw and would work. I assume. But that means using a toothed belt. Which if the blade should jam then I can see the motor burning out. It just seem odd that there is nothing orpther than mechano which I did consider but I'm concerned with the the rpm and the off balance scre used and the fact that most are just pressed plate.
                                    The 5000 rpm I got from the proxxon specs so I must have read them wrong. But that is the sort of thing I'm hopeful of making but as I've got six 12v motors and three sewing machine motors I want the flexibility of being able to change the motors as they wear out. But I can't do that with the modern direct drive we use here. Hence the need for pullies as gears would be to much of a strain on the motor but with idlers pullies to tension the belts. I can then make a tilting variable depth saw from a £30 model. And this is for making parts of similar dimensions to matches up to say 6mm acrylic and 20mm soft wood. And as the existing saw which is just a motor a grub screw flange and a switch. I have to make my own table then so long as the pullies are all the same size the speed should remain constant. But where to get the pullies required to transmit the power through the shaft so that the blade can tilt and rise and fall. Which needs at least two separate sections preferably three. So that's two shaft the power need to go along.
                                    #228513
                                    Izack Madd
                                      @izackmadd89335
                                      Posted by JasonB on 05/03/2016 10:09:30:
                                      This is exact what I need perhaps I a smallest sizes. As for pulley belts there are lads to choose from for RC cars. Which are cheap and short. I've got a way of fabricating a main drive shaft but was hopeful someone may be able to direct me to one ready made as my method is ver Heath Robinson. But will work.
                                      #228514
                                      Izack Madd
                                        @izackmadd89335
                                        Posted by Neil Wyatt on 05/03/2016 12:14:12:
                                        I do have a lathe a very small uni at style one. But I lack the skills and confidence for that to be the prime option and was hopeful that I could buy first and replace with better.
                                        #228517
                                        Izack Madd
                                          @izackmadd89335
                                          Posted by Michael Gilligan on 05/03/2016 07:20:48:
                                          Good point, John
                                          This is exactly the sort of working end I'm after but with the ability to tilt and rise and fall. For a table saw as it would this on its side. With two cams and worm screws for the tilting and riser.these are the bits that would have the power going through them as the drive shaft is also the pivot point. As the pivot point is actually the moving part not the pivot. But as it moves in an arc the centres remain the same. Hence the use of pullies to balance out the force or it would all be on one side causing very bad torque and inaccurate cuts.
                                          #228526
                                          Izack Madd
                                            @izackmadd89335
                                            Sorry that should have read I have a small 300mm centre Unimat style lathe. Works great if it wasn't for the nutter using it.smile p
                                            #228527
                                            Izack Madd
                                              @izackmadd89335
                                              If anyone reads this silly question
                                              As I can get hold of the right sort of pullies I think I want. But they have teeth. And so do the belts which are flat.
                                              But apart from the reduced friction side would it be possible to run a toothed belt inside out. That is with the smooth side contacting the pulley?
                                              That way I'd relive the issue of over friction and allow the belts to slip if needed. Or would they just slip completely without excessive tension?
                                              #228532
                                              Sam Longley 1
                                                @samlongley1
                                                When I first read the post i assumed that the 44 was a miss print & you meant 440mm not 44. Hence my reply was not relevant. Apologies
                                                Edited By Sam Longley 1 on 06/03/2016 07:42:15
                                                #228534
                                                  Sam look atthe likes of the Proxxon table saw, sort of thing ship modelers and dolls house makers use with small blades. This is why I also mentioned about pully size on the main spindle.
                                                  Izack for that small as saw I would forget about a rise and fall worked by a handwheel , simply have the table on a couple of slotted legs and adjust the height that way. Same with the table make that tilt as its far easier than the trunions needed to tilt the motor/ spindle assembly like on on full size saw. Sam may be aware of the old Kity Combi machine that work like this but that had a 200mm blade.
                                                  Edited By JasonB on 06/03/2016 07:44:07
                                                  #228540
                                                    Posted by Izack Madd on 06/03/2016 02:53:05:
                                                    Before that specific question gets lost … Yes, the small toothed belts [MXL for example] seem to work fine inside out, as a flat belt. I use them on my little 'Jason' lathe [running on pulleys designed for flat belts].
                                                    KWIL
                                                      @kwil
                                                      The smaller the pulley diameter the greater the slip with a smooth flat belt, which is of course why toothed belts are used by Proxxon.
