Odd Spanner
Odd Spanner
Home Forums General Questions Odd Spanner
  • #499284
    RichardN
      @richardn
      Random question- anyone come across a spanner like this before?
      Actually it is effective, and varies from 10-22mm. I assume continental origin based on the spelling and metric nature, and was found in a gutter years ago.
      Surprisingly useful, but never seen similar for sale? The irregular hexagonal ends rotate on the pins, in case that’s not obvious!
      #27675
      RichardN
        @richardn
        ‘Adjustable’ 10-22mm
        #499286
        Clive Foster
          @clivefoster55965
          There are several variants of this design floating around. I've handled two and seen at least three more illustrated / pictured.
          As you say they are effective but can be a pain to get on the nut or bolt head. Hopeless with the modern tapered all ways integrated bolt head & washer systems but can be very good on damaged heads.
          I din't particularly miss mine when it disappeared on loan.
          #499288
          David Hill 5
            @davidhill5
            I have a set of three to cover quite a size range. No idea where I bought them, might have been in Germany as I lived there for 15 years a couple of decades ago. Actually, can't ever remember using them as my first choice is always a proper spanner or socket!
            #499289
            roy entwistle
              @royentwistle24699
              I think I've seen them in Aldi, some time ago. I've certainly seen them before
              #499294
              Bo’sun
                @bosun58570
                Looks like an "Ideal Home Show" special. Bought because it looked good at the time, but then just languishes in a drawer somewhere, because a regular spanner is more convenient.
                #499299
                Rod Renshaw
                  @rodrenshaw28584
                  +1 for the Ideal Home Exhibition special. Worked OK for a time but snapped when it met a tight nut, and not really missed as it had a tendency to chew up the nuts.
                  Rod
                  #499311
                  Jeff Dayman
                    @jeffdayman43397
                    The slang in German for that wrench type, at least in Augsburg area, is "mutternwracke". Translated to English, it is "nut-ruiner" (for good reason).
                    #499316
                    not done it yet
                      @notdoneityet
                      Not the exact one, but I have one or two in one of my toolboxes… Rarely used.
                      #499317
                      peak4
                        @peak4
                        I do have a couple of those somewhere, but never been that impressed with them.
                        Cromna ones however, whilst no longer made, really do work well; they grip rusty and rounded fasteners, as well as round bar if used carefully. Available in sizes 1-4.
                        Cromna Front
                        I've not reproduced the photos here to save clogging up the forum storage, but there's a few either side of that photo in my flickr album.
                        There's also a few extra ones in my Facebook album if you have access to that particular social media.
                        Bill
                        #499411
                        Dr. MC Black
                          @dr-mcblack73214
                          I have one.
                          i think I bought it from Radiospares around 40 years ago.
                          i think I know where it is too!
                          #499503
                          Howard Lewis
                            @howardlewis46836
                            Have number of this sort of spanner, almost all unused, but seemed "A good idea at the time"
                            If the worst comes to the worst, a "footprint", Stilson or Mole wrench usually do the trick,, but at the expense of the the appearance of the piece being rotated.
                            #499516
                            Grindstone Cowboy
                              @grindstonecowboy
                              Have a very cheaply made version (no idea where from, I certainly didn't pay for it) that twists out of shape when used for anything even slightly tight.
                              I think the basic idea is good, if properly made. I prefer my Adjust-a-Box wrench though.
                              Rob
                              #499527
                              Peter G. Shaw
                                @peterg-shaw75338
                                I have one as in the photo at the top. On one side it says "#A210 Taiwan 3/8-13/16"" (yes one set of double apostrophes from the spanner, and one from me).
                                On the other side it says " (Strange symbol I can't reproduce) 15-22 MASTER9-14 N".
                                The heads are chromium plated, and coming off, whilst the main handle looks as if it might be chrome-vanadium.
                                Peter G. Shaw
                                #499537
                                Tim Stevens
                                  @timstevens64731
                                  There are many variations of self adjusting spanners around – in general it seems true to say 'They fit every nut equally badly'. But still, 100% better than stillsons – unless you have no regard for the skin on your fingers.
                                  And in case anyone has forgotten, the double apostrophe after a number often means inches. Or it did in the good old days.
                                  Cheers, Tim
                                  #499540
                                  Peter G. Shaw
                                    @peterg-shaw75338
                                    No Tim, I hadn't – I just wanted to be clear that it wasn't a typing error.
                                    Peter G. Shaw
