New Lathe, well maybe not “new”
Home › Forums › Workshop Tools and Tooling › New Lathe, well maybe not “new”
  • This topic has 19 replies, 13 voices, and was last updated 4 July 2015 at 17:36 by Roderick Jenkins.
  • #194331
    Oompa Lumpa
      @oompalumpa34302
      But new to me. A friend of mine who has an antiques shop called me up last week and said "I have a chap here trying to sell me a lathe, do you want it?
      What is it? was the obvious first question, "it's nice" was the answer so essentially I bought a pig in a poke. I had absolutely no idea at all as to what I had bought but I wasn't disappointed with the purchase, it is a lovely antique lathe with all the "bits" and it is actually in a very useable condition. I will not be using it of course, I have something else in mind for it (no – I will not be cutting it up/otherwise destroying it) but if anyone could give me any idea as to it's possible origins (other than from Jeff at the antique shop) I would be grateful as I am going to be asked the question innumerable times I would imagine.
      22" between centres and 31/4" from the bed to the centre of the chuck. Lovely thing it is too. No chuck key thoughsmiley
      graham.
      #17750
      Oompa Lumpa
        @oompalumpa34302
        #194335
        John Stevenson 1
          @johnstevenson1
          Seen one of these before.
          It's a lathe.
          #194339
          Rainbows
            @rainbows
            Would I be correct to say that the bed design is one generally more popular with USA made lathes?
            #194342
            Oompa Lumpa
              @oompalumpa34302
              Posted by John Stevenson on 21/06/2015 17:21:10:
              It's a lathe.
              Yes, but I think it is ambidextrous though as there is a steady rest (shown not so well in the top photograph) that looks "woodworking-ish".
              graham.
              #194343
              Rik Shaw
                @rikshaw
                If it were mine I would send a pic to Tony at "lathes" and hope he can come up with an answer for you. A lovely looking machine and one that could arguably be described as an instrument makers lathe.
                Rik
                #194358
                Ian P
                  @ianp
                  Graham
                  Can't help with the lathe, but it looks quality.
                  Any news on the EDM yet?
                  Ian P
                  #194367
                  frank brown
                    @frankbrown22225
                    Looks old, Pre 1910? have you measured the tapers?, some are patent to one lathe manufacturer.
                    Frank
                    #194368
                      Graham,
                      It has general look of WolfJahn
                      The angle scale for that top slide is rather impressive … Could you do a detail photo, please.
                      Bazyle
                        @bazyle
                        It is like a George Adams 2 1/2 clockmakers lathe (bigger than watchmakers) though it is a bit more elaborate than one of those. Hence the hand rest – not for woodworking.
                        #194383
                          Interesting that you should mention George Adams, Bazyle
                          The opening paragraph on this page is quite revealing.
                          Roderick Jenkins
                            @roderickjenkins93242
                            Graham,
                            Have a look at the Lorch Model A
                            HTH
                            Rod
                            #194394
                            Ajohnw
                              @ajohnw51620
                              My father told me that there were variations on a V and flat lathes beds about well prior to WW II.
                              I would like to see a close up of the whole angle setting area and one of the lead screw dials. I have seen a lathe some where with the angle scales and a long pointer like this one but as there appears to be 2 scales I'd be inclined to think that in this case it's an add on. Also from it's appearance I wonder if the slide rest actually belongs to the lathe, Is the slide rest fitted to a block which is shaped to fit the bed and also looks like it has more age in the same way the other bed fittings do?
                              Roderick Jenkins
                                Hi Graham,
                                This posting turned up over on MEM:
                                It looks very much as if yours is an early Lorch
                                Rod
                                Edited By Roderick Jenkins on 02/07/2015 11:35:16
                                #195579
                                Ian S C
                                  @iansc
                                  Rod, I'd tend to agree, unless it's a copy.
                                  Ian S C
                                  #195624
                                  Phil Whitley
                                    @philwhitley94135
                                    Looking at the unusually long travel on the compound and the long and elaborate angle indicator which would increase the accuracy for angle setting, I would hazard a guess that this machine is designed for taoer turning.
                                    Phil
                                    #195625
                                    Phil Whitley
                                      @philwhitley94135
                                      TAPER!! turning that is!
                                      #195744
                                        Those ring-nuts 'ring' a bell.
                                        I remember an article in an old ME on someone making a replacement one for an old lathe – now if we could find the article I bet it's the same lathe…
                                        Ajohnw
                                          @ajohnw51620
                                          I think those weird shaped nuts are an English thing. However I dont think that it is one of these
                                          laughNice nuts – can put a crow bar through them to do some English heavy duty turning. I'd guess the slide rest – the name of the cross and compound, is I suspect continental or at least doesn't belong with the lathe. Hence the couple of questions I asked.
                                          Roderick Jenkins
                                            The last illustration of the Lorch model A iv on Tony's site shows ring nuts and a similar unbalanced handle on the"topslide".
                                            Rod (possibly flogging a dead horse)
