Need assistance on wiring for my lathe motor
Home › Forums › Workshop Tools and Tooling › Need assistance on wiring for my lathe motor
  • #19865
    ron vale 3
      @ronvale3
      #486028
      ron vale 3
        @ronvale3
        The preamble
        I know NOTHING about elecrics..Sad i know but some people grasp it, other dont, i am one of them, so anything that tells me that this winding is secondary and voltd,amps watts go right over my head pleae do not get techbical it will not help Sorry to be blunt but that is the way my brain is. It jsut cannot get anything electrical in it… even computers i have trouble with, ( but onlt the theory side, using them is ok ,but if it doesn;t work, the i get someone in)
        Thats it
        Now a few weeks ago my Crompton motor has been making 'noises'
        disconnected the wires from the motor from the Dewhurst rotary switch and noted what went where so far so good this, i can deal with
        Took it to the local motor repair shop.. new bearings reqd Fixed and brought home yesterday And this is where the problems start. The gremlins that live in the shed have taken the diagram of what went where!!
        Not to worry there is a diagram on P19 Fig 25 of the set up to contact it all back. AAARGH the colours are all wrong
        jumping forward a bit the terminals on the dewhurst are ion the LH side T1-4 and on the right T5-8 there is an earth connector above T5
        Still with me?
        The powerto the switch uses T1 Brown and T3 Blue which corresponds to the Fig 25 diagram
        Now this is where my brain goes into neutral
        Fig 25 shows that connections of the motor , wire colour and termination on the switch as,
        A1 black T5
        A2 black T7
        Z1 red T2
        Z2 red T6
        However my motor set up has the following
        Terminal A brown
        A2 brown
        T blue
        Z blue
        Which knackers me what colour is now what?
        To make it really confusing is when i did a continuity test i gor the following results ( i call the blue ones B1 and 2 and the Brown as B1 and 2
        Thr battery used showed 1.4v ( see i do know a bit!!)
        B1 to Z 1.67??????
        B1 to T 1.4
        B2 to Z 1.4
        B2 to T 1.4
        Br1 to A 1.4
        Br1 to A2 1.4
        Br2 to A 1.4
        Br2 to A2 1.4
        I was hoping to get a 0 on a couple of these readings!!
        Now any ideas on what wire i put on what terminal
        IIRC the browns went T2 and 6. which equates to the red in fig 25
        Blues must go on T5 and 7
        If i just connect them up what could go wrong and if the motor runs backwards in the forward position. wI suppose i would have to reverse 2 wires but what ones
        In times like this i am glad i turned down that job in Bomb disposal!!!
        Any thoughts and explained so a three year old can understand?
        Sorry for the length of this Hopefully all the info you need is there
        #486054
        ron vale 3
          @ronvale3
          Sorry, left off the bit where i found the diagram. It is Fig 25 on P19 of the Myford S7 manual
          #486140
          Emgee
            @emgee
            Ron
            Have you details of the information on motor plate ?
            How many wires come from the motor and what colours are they ?
            A picture or 2 of the motor terminal box may help.
            Emgee
            #486158
            ron vale 3
              @ronvale3
              Emgee
              It is now back on the lathe and picture taking is a bit awkward!
              The switch is a Dewhurst drum type that has forward and reverse
              The Myford S7 manual (i think you get download it) on P19 Fig 25 shows the wiring diagram for such a switch
              The motor sows four terminals A1 and A2 and Z1 and Z2
              A1 is black and goes to Switch T5
              A2 is black and goes to Switch T7
              Z1 is red and goes to to switch T2
              Z2 is red and goes to switch T6
              My motor is a Brook Crompton Parkinson and has four terminals
              Z AZ A T
              Z is Blue
              AZ is Brown
              A is Brown
              T is blue
              I feel rather aprehensive of doing a 'i will just try this….' just in case i blow up half of Berkshire!
              If you could say put this blue from Z on Terminal X and the brown from T on term Y
              is really all i need.( plus the other two locations)
              The change of terminal nomenclature threw me completely and the change of colour just put the icing on the cake!
              #486171
              Brian Morehen
                @brianmorehen85290
                Motor Blue is now neutral was Black
                Brown is now Live was Red I presume this is now the colours of the leads on your repaired motor
                If the motor leads were disconnected from your Dewhurst control by you The only difference is in the colurs beingchanged whichis the new format IE Blue was Black Neutral Brown was Red Live
                Hope this is the answer to your problem I think it is really the fact that the colouse on your motor have changed.
                Regards Bee M
                #486182
                Malc
                  @malc
                  Hi Ron,
                  I have an ML7 running on a Crompton motor with a Dewhurst switch. I have a diagram of my set-up (Word document) . If you PM me I will email you a copy if you think it will help.
                  Malc.
                  #486194
                  ron vale 3
                    @ronvale3
                    Malc
                    If your terminals on your Crompton are like mine Z, AZ, A T in the sequence Blue, Brown, brown, Blue that would be great
                    Ron
                    I have forearms like Popeye cranking the thing around by hand, and no monkey to dance to the music!!
                    #486196
                    Malc
                      @malc
                      Ron,
                      My motor has the same lettering as yours but I have used my own colours of the cable I used between the motor and the Dewhurst switch. I will try to send you a copy using the “Message member” at the bottom of your post but I don’t usually have much luck on this site.
                      Malc.
                      #486198
                      Malc
                        @malc
                        Ron,
                        Sorry but I don’t think the diagram went with the message. Send me your Email address if you would like it.
                        Malc.
                        #486559
                        ron vale 3
                          @ronvale3
                          Case now Closed, and a VERY BIG public Thankyou to Malcolm, who 'held my hand' and got me there in the end
                          Thanks again Malcolm..I owe you a few beers
                          Ron
                          #486563
                          Harry Wilkes
                            @harrywilkes58467
                            Thanks for letting us know and glad you got it sorted
                            H
