Posted by DMB on 29/03/2015 09:56:36:
Would it be easier to copy Myfords and drill and tap a new locking in a new a new location?
I guess it could be done (not too many times though). The difficulty is that I'm doing it in situ and it would need a portable drill – not the best for accuracy plus the fact that the steel is (presumably) fairly tough. I also barely have enough room at that end of the lathe to get the drill in, let alone stand behind it to get some weight on it.
If I took the whole head off the lathe and set it up on the mill-drill it would probably work better …. but that means a realignment when replaced.
Life shouldn't be so hard
