Hi All,
Sourcing one of these bull wheels is proving very difficult if not impossible.
I do not have the heat source to get this to hot enough for brazing and the 3 local shops I have been to will either not touch it or want around £100 to 'maybe' do it!
I also have virtually no experience at welding or brazing let alone cutting gear teeth.
The answer I seem to have come up with is to try and use one of the spare 65 tooth change wheels, bore it out a bit larger than the 1" needed and then make a brass or bronze bush to fit that is thick enough to allow a grub screw to be drilled and threaded to fix to the spindle. Perhaps secure with Loctite or put the bush in freezer before fitting? Maybe pin it to the gear?
I realise that the change wheel is slightly narrower than the original but hopefully will be OK.
Does anyone have any reason on why not to go this route or any other suggestions or advice please.
This will be quite a test for my level of experience so could turn out OK or end up in the bin!
Cheers, Martin
