Mini taper?
Mini taper?
Home Forums Workshop Tools and Tooling Mini taper?
  • #187455
    john knowles 1
      @johnknowles1
      I have just bought a Wakefield 1.25" lathe. I need a revolving tailstock centre but don't know what the taper is. The large end dia of the old chuck (worn) taper is .342" small end dia is .300 the taper is 1" long. Any ideas would be appreciated as I cannot find anything on the internet.
      Thanks in advance.
      #17688
      john knowles 1
        @johnknowles1
        #187476
        Roderick Jenkins
          @roderickjenkins93242
          Those dimensions are similar to the tapers used on Flexispeed lathes, which is the small half of a No. 0 Morse taper. Sadly, I don't think you'll find anything commercially available. The parallel shank of a rotating centre for a C0 lathe from arceuro can be turned down to a fitting taper.
          HTH
          Rod
          #187488
          AndyP
            @andyp13730
            Cowells use that short No. 0 Morse taper in the tailstock so their rotating centre should fit but sit down before you see the price !
            Andy
            #187490
            john knowles 1
              @johnknowles1
              Thank you both for your responses. If I need a seat before I see the price I don't think I'll go there. Maybe turning one down is the answer as Rod said, but this lathe doesn't have a swivel saddle. cheers again..
              #187496
              Andrew Hutchinson
                @andrewhutchinson12802
                If it is No.0 MT you 're looking for then Sherline sells a full range of items. Eyeballed with a digital caliper my dead centre was .362", .320" over .848". They have a nice little revolving tailstock centre as well as a range of gear that can be offset to fix a tailstock height error for work that demands it. The prices are fairly cheap considering they are made in America. Usual disclaimers.
                #187510
                blackcat smith
                  @blackcatsmith57530
                  Soba ref no 201640 from chronos
                  #187511
                  blackcat smith
                    @blackcatsmith57530
                    If its like my tiny lathe it might be too long..
