Laser cut or water cut
Home Forums General Questions Laser cut or water cut
  • #27878
    Former Member
      @formermember12892
      #517890
      Former Member
        @formermember12892
        #517893
          Mine were laser cut and can't see a reason why waterjet would really be worth paying extra for as finish was very good to 1 thou.
          #517895
          Former Member
            @formermember12892
            #517936
            old mart
              @oldmart
              Certain alloys could be affected by the local heat of the laser.
              #517951
              Andrew Tinsley
                @andrewtinsley63637
                I purchased some round blanks laser cut from sheet. The edges were incredibly hard and a file would barely touch them. So beware, you may get a shock when you try tidying up the cut. . In my limited experience, you don't get this problem with water jet cutting.
                Jason B seems to be happy with his laser cutting, so hardness of the cut seems to vary.
                Andrew.
                #517956
                John Haine
                  @johnhaine32865
                  Jason implies that finish machining wasn't needed ("very good to 1 thou&quot. I think that's what determines the way to go – I've also found laser and flame cut plate has very hard edges.
                  #517959
                  Tony Wright 1
                    @tonywright1
                    Hello ,I had some laser cut connecting rods .Very accurate, saved me hours of work with the hacksaw .The only trouble I had was the out line was so hard couldn’t touch them with a file ! So out with the blowtorch heat up to cherry red and left them to slowly cool . That did the trick allowing me to clean them up with a file ! and emery cloth .Hope this helps someone struggling to clean up laser cut parts.
                    #517961
                      Well it was either that or the mating parts I made had matching errors to the platessmile p
                      The crank/2nd shaft bracket slipped into it's holes as did the 3rd/rear axle. As you can see these two castings have raised circular bosses that locate in holes laser cut into the horn plates, they fitted without any slop. Can't remember now if I even needed to drawfile the cut edges, may have just given them a quick lick with some emery around a file. All the small holes I drilled.
                      #517974
                      duncan webster 1
                        @duncanwebster1
                        The hard edge on laser cut is very thin, went over mine with a flap wheel and it was then file-able. A diamond file would probably work as well.
