Into the darkness
Into the darkness
Home › Forums › The Tea Room › Into the darkness
Viewing 25 posts - 1 through 25 (of 26 total)
  • #36449
    Harry Wilkes
      @harrywilkes58467
      #549031
      Harry Wilkes
        @harrywilkes58467
        Sales of halogen lightbulbs are to be banned in the UK from September, with fluorescent lights to follow, under government climate change plans.
        Better start getting a stock of candel's
        H
        #549036
        Martin Kyte
          @martinkyte99762
          Why?
          #549039
          Jon Lawes
            @jonlawes51698
            Because you can't smash a Spinning Jenny in total darkness.
            #549042
            Speedy Builder5
              @speedybuilder5
              Do you have to have special LED dimmer switches for dimmable LED bulbs ? I ask this as I changed the halogen bulbs for LEDs which sort of work OK, but some of the LEDs on the same circuit can dimly glow when all is turned off.
              Bob
              #549043
              Oldiron
                @oldiron
                Posted by Speedy Builder5 on 09/06/2021 16:51:16:
                Bob
                Yes you do. I have a large central chandelier type light fitting and have replaced the Halogen lamps with LED's. The dimmer I got from an electrical wholesaler cost £70 so they are not cheap.
                regards
                #549044
                Mick B1
                  @mickb1
                  Mostly hype and propaganda, at least in the short term. All that'll happen is that people's central heating systems will run for that bit longer to replace the few hundreds of watts auxiliary heat generation lost by the change to LED, so that the part-renewable electricity consumption will be replaced by fossil fuel heating.
                  #549045
                  Calum
                    @calumgalleitch87969
                    I'm all in favour of switching to LED where possible, and believe it will be a good thing, but I would like to see LED bulbs properly guaranteed. I object to paying ten times the cost for something that often lasts no longer. I bought three LED bayonet fitting bulbs last summer and all three have since met their demise.
                    #549046
                    Richard Marks
                      @richardmarks80868
                      Company called Dazz Led worth looking at.
                      #549051
                      Mike Poole
                        @mikepoole82104
                        I suspect halogen sales are in steep decline already. There are certainly questions to be asked about the poor longevity of some LED lamps. Most people do not relate to the claims made for lamp lifetime in hours and the number of times a lamp is cycled is likely to be a factor in reducing life of the lamp. It would be difficult to claim for a lamp that doesn’t meet expectations as no one logs lamp running time or cycles. I think someone brought up the point that some markets demand a higher performance lamp and they do exist. Maybe the government should insist on better performance lamps for the consumer.
                        #549052
                        David Noble
                          @davidnoble71990
                          Posted by Jon Lawes on 09/06/2021 16:32:51:
                          Sometimes, only a smiley will do. 😂
                          David
                          Edited By David Noble on 09/06/2021 19:01:04
                          #549054
                          Bill Dawes
                            @billdawes
                            I have a bucket full of halogen GU10 lamps (got told off by sparks for calling them bulbs, you plant them in the garden he said) a result of replacing with LED. My dimmer switch for LED (you need dimmable lamps as well) was from Screwfix, a Varilight leading edge dimmer if I remember right, about £15.
                            All my LED, including an outside light fitting are lasting well, couple of years or more so far.
                            Bill D.
                            #549056
                            old mart
                              @oldmart
                              When I did up the spare bedroom above the extension about 12 years ago, I fitted two lamp fittings each with 3 GU10 230v 50W halogens, controlled by a 40-400W rotary on/off tungsten dimmer. In the last few years, dimmable 230V GU10 LED bulbs became available and I just changed the lot. They work like the old ones, but use much less electricity. The LED bulbs are LAP brand dimmable 5W warm white, 346 lumen.
                              #549060
                              Mark Rand
                                @markrand96270
                                I'm more than a bit narked about the plan to ban fluorescent tubes in the near future. LED tubes have, pretty much, exactly the same lumens/Watt as T8 triphosphor fluorescent tubes. The only ones that even claim a better output only emit over 180° of their circumference.
                                #549067
                                duncan webster 1
                                  @duncanwebster1
                                  Posted by Mick B1 on 09/06/2021 17:21:26:
                                  I don't run my central heating in summer, but I do have the lights on after dark
                                  #549070
                                  old mart
                                    @oldmart
                                    Bob
                                    Not quite the same, but the flourescent tubes in the kitchen used to dimmly glow when switched off and I found that the light switch was on the neutral side instead of the live.
                                    #549089
                                    DiodeDick
                                      @diodedick
                                      There is a sting in the tail of the proposal to ban flourescent tubes: Because they are fed through a choke/ capacitor network ( in the fitting in a domestic application) they run mostly on reactive power not "true watts". That is why a 4ft flu is sold as "equivalent to a 60 watt lamp" It has a light output equivant to, but does not draw the power of a 60w lamp. Traditional meters with a spinning disc visible only measure the true watts, not the reactive power. Which in practical terms means you can leave a flu' on 24/7 for free! I cannot speak for so-called "smart meters" which cannot do every thing that the ad-men claim, unless there is a current sensor in every light fitting and one for each half of a 13A twin outlet, which would cost far more than they could ever save you.
                                      Still, I am glad that I got that off my chest.
                                      Stay safe and keep turning.
                                      #549095
                                      Mark Easingwood
                                        @markeasingwood33578
                                        Well I rent an Industrial Unit from the local authority, it's lit with twin 8 ft fluorescents, via spinning disc meters.
                                        The lights certainly spin the discs, and cost more to run, than much of my industrial woodworking machinery!
                                        #549097
                                        Ian Johnson 1
                                          @ianjohnson1
                                          Oh no!!! I've got a rather lovely Mathmos Telstar lava lamp, it uses halogen lamps. Looks like I need to stock up!
                                          IanJ
                                          #549106
                                          James A
                                            @jamesalford67616
                                            Posted by Oldiron on 09/06/2021 17:08:57:
                                            Bob
                                            regards
                                            No: you do not need a different dimmer, unless we happened to have the right type already. I fitted dimmable LED bulbs to replace some filament bulbs and the existing dimmer switch worked perfectly.
                                            James.
                                            #549115
                                            DiodeDick
                                              @diodedick
                                              Although I did not labour the point, I was referring to domestic installations, which is where most model engineer's hobby rooms are.
                                              Industrial installations (where a significant number of flu's are used) have power factor correction networks added to make you pay for your electricity and to restore the balance of reactive power in the grid. Domestic installations where there is usually just one or two tubes do not. If you get the chance to see inside the Control Room of a power station, you will see that beside the MW output meter there is another the same size labelled MVAR ( Mega Volt Amps Reactive) which tells us how seriously reactive power is taken. The MVAR gauge is centre zero, say 50-0-50 for leading and lagging power. The reactive power taken by a few tubes is no more significant in grid terms than the odd 60 watt lamp, however on an industrial scale it is.
                                              Mark's unit sounds like it is part of a set-up big enough to justify power correction) and the bonus of three phase power, which is totally separate from the power correction issue).
                                              #549117
                                              Steve Skelton 1
                                                @steveskelton1
                                                The cost-effectiveness of LED lamps depends mainly on their design and construction.
                                                LED's have to run cool to give the quoted hours life and therefore getting rid of the heat they produce is paramount so heat sinks are really necessary for any lamp that produces a usable output.
                                                Ceiling mounted GU10's are the biggest problem as people stuff insulation around them so even with a good heat sink they often cannot dissipate the heat fast enough and the LED starts to degrade and the output will drop over time.
                                                Unless the light output efficiency can be improved (ie heat generation reduced) GU10 replacements are unlikely to be truly cost-effective.
                                                #549119
                                                noel shelley
                                                  @noelshelley55608
                                                  The issue of LED life span is very well explained in the context of the Dubai light bulb by bigclive on youtube. I always prise out the lens/ difuser on LEDs to aid cooling, you also get more light ! Noel
                                                  #549122
                                                  John Haine
                                                    @johnhaine32865
                                                    Posted by Steve Skelton 1 on 10/06/2021 09:43:39:
                                                    Biggest problem for me was the tiny puck-shaped power unit reducing 240V for a couple of LED spots that a "professional electrician" buried in the roof insulation. When they failed I discovered that it had undergone a "loud brown smell" event, fortunately not setting the house on fire in the process! This was the same guy who installed new consumer units and pronounced there was an earth fault on the lighting circuit which he'd have to come back and fix. Next day there was no hot water – he had wired the immersion heater to the lighting so when the time switch turned it on the breaker tripped.
                                                    #549133
                                                    Oven Man
                                                      @ovenman
                                                      I have quite a collection of duff GU10 LEDs waiting to find a use for them. In every case the actual LEDs are OK it is the driving electronics that have failed. Just recently took a Morrisons GU10 LED apart. Difficult to see the point of using heat sink compound between the aluminium of the LED base and the plastic outer shell of the lamp.
                                                      Peter
