Heavy cupboards?
Heavy cupboards?
Home › Forums › Hints And Tips for model engineers › Heavy cupboards?
  • #310244
    Rik Shaw
      @rikshaw
      Just found these in one of those marketing "comics" you find inside magazines. Cheap enough and maybe useful to some of us?
      Rik>>
      **LINK**>>
      #30625
      Rik Shaw
        @rikshaw
        #310255
        Clive Foster
          @clivefoster55965
          Handy beasts. very effective within their limits.
          Got the LiDL version way back first time they had them. Probably been 4 or more opportunities since!
          They do like fairly smooth floors. My workshop is fine as I used the waterproof version of standard chipboard underflooring sheets. Usual concrete / garage floor may be bit too rough.
          Need to think about where and how you push as the load isn't positively restrained on the wheels. Just rubbery grip pad. So if a wheel set hits something and stops its not that hard to shove a corner off. How did I find out?
          Idea of many small disk rollers can effectively be scaled up. I have a similarly low profile variant with 4 square inches or so of rollers on each end of a pair of steel tube sticks to pull my Smart & Brown 1024 away from the wall on its annual backside inspection. About 1 1/2 tons there. Steel tube sticks are 1" square tack welded together.
          Clive.
          #310262
          Mark Rand
            @markrand96270
            "Supports up to 150 kilograms".
            Might be useful for moving a single draw out of a cupboard. Not a lot of use for any of the cupboards complete with contents…
            #310270
            Clive Foster
              @clivefoster55965
              C'mon Mark be nice.
              I've had almost 400 lb on my LidL versions and they survived. More than I really wanted to push around myself but beat the heck out of pry barring on nice (not workshop!) floor.
              Clive.
