Harrison M300 Apron
Harrison M300 Apron
Home › Forums › Manual machine tools › Harrison M300 Apron
  • #493834
    Len Morris 2
      @lenmorris2
      Hi Everybody,
      I want to remove the drive shafts that pass through the apron, the lead screw and the feed drive shaft. They are all released at each end and seem to just slide out. My concern is that if I pull them out something will go clunk inside the apron causing major work. Any advise much appreciated.
      #14015
      Len Morris 2
        @lenmorris2
        #493839
        Clive Foster
          @clivefoster55965
          Looking at the parts book I'm pretty certain that the drive worm and key will drop out of position when you pull the feed shaft.
          Might be possible to ferret things back into place if you remove the bottom plate from the apron if you start with the keyway in the shaft at the bottom.
          Best to follow the procedures and pull the whole apron off so you can see whats inside. Apart from the sheer awkwardness of dealing with the lump with screws sticking out its usually relatively easy that way whatever the machine.
          #493841
          DC31k
            @dc31k
            Go into back garden.
            Cut stick from hedge.
            Whittle it down until it is the same diameter as the shaft you are removing.
            Insert from opposite end to which you are removing shaft.
            #493854
            Len Morris 2
              @lenmorris2
              Thanks for that. This job is going on as we speak so thanks for your quick replies. The lead screw slid out easily. Looking inside there was no displacement of the nut halves and they moved correctly with the control handle. Suspect the worm drive will displace so like the idea of chasing the shaft through with a dummy. Going to give it a go now and report back later. Just wondering what best to use, pine, oak or firsmiley.
              #493866
              Len Morris 2
                @lenmorris2
                Well, the job is now done. As it's pouring down outside decided to give the garden a miss, pull the shaft and deal with any fall out. There where none! The shaft slides down a continuous tube with a fixed key. Shaft out, shaft in, no problem at all. The problem we all face is having parts diagrams (that need forensic examination) and no decent service instructions. Hope this helps any Harrison owners.
                Regards to all
