Harold Hall grinding rest
Home › Forums › General Questions › Harold Hall grinding rest
  • #113352
    Brett Hurt
      @bretthurt41827
      What do I have to do to modafie it to a bolder 8in grinder, Iam going to build one and would like it fit my grinder, and need to know any problems with the build.
      #22493
      Brett Hurt
        @bretthurt41827
        #113353
          Probably just reduce the packing under the grinder by 1" to keep the centre height the same as a 6" assuming Harold based it around a 6" grinder
          #113355
          Harold Hall 1
            @haroldhall1
            Actually Jason I have never quoted a height for the packing shown on my photographs, I think now that I should have done. However, thinking about it, spindle height is the better measurement that I should give. Something to add to the website. I have been to the workshop to measure the arrangement I have and the grinder spindle is at 6-1/4 in.
            This value Brett is far from critical but looking back on the times I have used it getting the rest low enough was more likely to be a problem than raising up to a higher level.
            I would therefore take that dimension as a minimum and suggest anywhere between 6-1/4" and 7-1/2" would be a good value to aim at. As Jason says add some packing if you are lower than that.
            Are you aware that on my website there are two pages that show modifications that are worth considering, though by no means essential. There are also pages on using it for numerous sharpening tasks.
            I have detailed some of these elsewhere on the forum but if you would like I can quote them here to make it all in one place for you.
            I am sorry, I keep forgetting to ask which one you are making, from which book or MEW issue.
            Harold
            Edited By Harold Hall 1 on 28/02/2013 19:54:02
