Half Nut
Half Nut
Home › Forums › General Questions › Half Nut
  • #22787
    Alan .204
      @alan-204
      #127626
      Alan .204
        @alan-204
        If you have read Robs post on the Deckal Jam you will Know we found the problem and freed every thing of and now all seams well, this is apart from the half nut which is worn out so we need to make a new one and guess who got the job, screw cutting is not a problem as I've done quit a few on the lathe and seam to do ok, but I've never cut an acme lead screw thread so I will need some help along the way, my first question is the ID as the thread inside the half nut has almost disappeared am I right in thinking if I measure the OD of the thread between the thread on the lead screw is that my ID, help with this would be much appreciated and I hope to post pictures as I go, don't want to cock this up as the price of the material is expensive phosphor bronze.
        Regards Alan.
        #127630
        Anonymous
          Yes, but; there's usually an allowance on both ID and OD so that the thread engages on the flanks, not on the crests. All the details are in Machinery's Handbook. It is traditional to make a practice piece in a less expensive material, such aluminium, to check form and fit.
          #127685
          Alan .204
            @alan-204
            Thanks Andrew I don't have a copy of the machinist hand book you talk about is there a guid for the allowence you talk about.
            Al.
            #127687
              Enter the OD* of the leadscrew and tpi here and it will give you the rest
              The OD will be a nominal size eg 0.625", 0.750" etc
              And the formulas here
              Edited By JasonB on 23/08/2013 16:35:40
              #127712
              John Stevenson 1
                @johnstevenson1
                Hang on.
                If it's a Deckel chances are it's metric and a trapezoidal thread form at 30 degrees.
                #127736
                Hopper
                  @hopper
                  Posted by Alan .204 on 22/08/2013 21:56:38:
                  …the material is expensive phosphor bronze.
                  You might want to look into that choice of material. Phosphor bronze can be quite hard and can wear non-hardened steel shafts and leadscrews. For a soft steel, a softer leaded bronze/gunmetal may be a better choice. Depends I suppose on how hard the leadscrew is and how concerned  you are about it wearing.
                  Edited By Hopper on 24/08/2013 10:05:41
                  #128163
                  Alan .204
                    @alan-204
                    Will hopefully try to get the new half nut made this weekend, I've started with grinding up the Acme thread cutter if you look at it and see anything I've done wrong please let me know, Andrew thanks for the advice it makes sense to make a trial one out of ally first so that's what I shall do, Jason thanks for the link that will be very handy, John you are right most of them appear to be metric but this one isn't it's imperial, Hopper I see what you mean but as we only have the phosphor bronze it will have to do, spoken to Rob whose mill it is and his thoughts are if the miller was in use for 8-10 hours a day we would look for some thing else like you suggest but the use the miller will get we will all be dead and buried before the lead screw is worn out.
                    Al.
                    #128226
                    Robonthemoor
                      @robonthemoor
                      Al, will that make a v type of cut? I thought the thread was straight sided! More like U with a flat bottom,
                      Rob.
                      #128227
                      Ady1
                        @ady1
                        Start with cutting the v
                        Then square it up as required wit a second tool
                        Cutting it out in a single chunk is a PITA
                        Edited By Ady1 on 30/08/2013 14:46:53
                        #128228
                        OuBallie
                          @ouballie
                          mrpete222 (tubalcain) has a set of videos on YouTube showing how to do Acme.
                          Series starts with his Machine Shop Tips #24
                          Geoff – Run out of things to say. Bummer!
                          #128232
                          Alan .204
                            @alan-204
                            That's the form it should be so it will be ok I think, Andy I can't start with a v shaped cutter because it's an internal left hand thread, one I start to cut the thread I don't want to risk anything moving so I thought best to go in straight with the cutter I ground but very slowly and 5 thou at a time maximum, unless any one can give me a better way to do it.
                            Al.
                            #128252
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              Hi Alan ,
                              Screw cut undersize .
                              Make / buy : ACME tap / form tool / chaser / thread finisher .
                              Most ACME taps available . Use as is or grind lots away to make form tool .
                              Bought is easier but not that difficult to make silver steel DIY versions .
                              Regards ,
                              MikeW
                              #128262
                              Alan .204
                                @alan-204
                                Finally got the lead screw picked up today and it measures 8TPI and the OD = 0.950 so I have gone for 0.828 for the ID don't know if this is correct but I will find out tomorrow when I thread a piece of ally which I've bored out ready in the lathe, if I have the ID wrong just tell me before I cock it up.
                                Regards Alan.
                                #128265
                                Robonthemoor
                                  @robonthemoor
                                  0.122 divided by 2 = 0.061 sounds a little tight, but easy to take off not so easy to put back on.
                                  Rob.
                                  #128278
                                  Robonthemoor
                                    @robonthemoor
                                    Sorry al completely misunderstood, I have sent the guys on the forum into a spin,
                                    rob
                                    #128290
                                    Alan .204
                                      @alan-204
                                      So today started to make a trial nut just to check I've got everything right, cut and faced of a piece of ally round bored out and cut the thread, lead screw would not fit after abit of head scrathing thinking I've got a measurmet wrong I grabbad the old half nut and screwed it onto the lead screw and to my amazment its a right hand thread the one I cut was left hand, can't tell you the names i was calling myself I couldn't belive I made such a stupid mistake all I needed to do was check it befor I started, (don't know why I did it) anyway made another one and it fits well so next will be the phospher bronze.
                                      This is the right one.
                                      #128331
                                      Alan .204
                                        @alan-204
                                        Got a bit more done yesterday it's ready to bore out to size will do some more this afternoon after Moto GP if the wife lets me.
                                        Al.
                                        #128386
                                        Alan .204
                                          @alan-204
                                          Finished boring out the half nut ready for threading, drilled out to 14mm
                                          img_0173.jpgMade a boring bar for the job and took it out to size.
                                          img_0175.jpgCut the Acme thread.
                                          img_0176.jpgChecked the fit just what I was hoping for, thank's to every one for all the advice and help with this one, only ever cut one internal thread before so I'm pleased how it turned out.
                                          Cheers Al.
